OdyClub Forums - General Discussion New Page 1
Home  User CP   Register   Calendar   Member   F A Q   Search
OdyClub Forums : Powered by vBulletin version 2.3.11 OdyClub Forums > General Forums > Problems and Concerns > Jammed power sliding door on EX model
  Last Thread   Next Thread
Author
Thread Post New Thread    Post A Reply
JoeG
Junior Member
Question Jammed power sliding door on EX model
Passenger side sliding door is jammed, inside and outside handles both ineffective, lock slider jammed in unlock position and cannot be moved into lock position even with major pressure. Door is therefore stuck shut and inoperable. No warning lights or controller diagnostics. Anybody seen anything similar??
Old Post 07-15-2003 01:03 AM
JoeG is offline Click Here to See the Profile for JoeG Find more posts by JoeG Add JoeG to your buddy list Edit/Delete Message Reply w/Quote
canadaodyowner
Senior Member
Hi JoeG,
let's start with some dumb questions. does it beep when you pull on the handle? what happens when you push the driver's lock/unlock button up/down? what about the sliding door on/off switch on the dash? any blown fuse?
__________________
'00 EX.
'03 Corolla CE.
Old Post 07-15-2003 01:14 AM
canadaodyowner is offline Click Here to See the Profile for canadaodyowner Click here to Send canadaodyowner a Private Message Find more posts by canadaodyowner Add canadaodyowner to your buddy list Edit/Delete Message Reply w/Quote
JoeG
Junior Member
Should have included that info to begin with. The other door is fully functional and not disabled via the dash switch. No beeping, and no reaction to the power lock unlock function. The jammed door is simply completely inert while the other door functions normally.
Old Post 07-15-2003 01:49 AM
canadaodyowner
Senior Member
I did a search, perhaps this will help?
http://www.odyclub.com/forums/showt...fuse+power+door
__________________
'00 EX.
'03 Corolla CE.
Old Post 07-15-2003 06:56 AM
Mondoman
Junior Member
About two weeks ago, we were visiting my grandmother out in the middle of Kansas and our passenger slider just quit working. It seems that my wife pulled on the handle at the same time that I pushed the open button on the dash and the door just stopped. Unlike your problem. the manual mode worked fine, the drivers side door worked fine (auto mode), it was just the passengers door (auto mode) was not working. I ended up opening and closing the door manually a couple of times but to no avail. I had done the all gear/dual slider modification a couple of months before and thought that maybe it had caused some sort of short in the electrical panel. Closed the door, drove to the nearest Wal-mart to finish our outing and it started to work again. The only thing I can think of was that I had somehow reset/retrained it by opening and closing it a couple of times. Hasn't happened again sense, (knock on wood).
__________________
2003 EX SBP w/ OEM Fogs, tow package, wheel locks, bug guard, mud flaps, cargo tray, door edge guards, & head/fog light protective film.
1995 Integra LS 4d, 127,000 miles and still running strong
1995 Ranger XLT LB Its a ford, it just runs, but thats ok with me
Old Post 07-16-2003 08:15 PM
Mondoman is offline Click Here to See the Profile for Mondoman Find more posts by Mondoman Add Mondoman to your buddy list Edit/Delete Message Reply w/Quote
Show Printable Version | Email this Page | Subscribe to this Thread
Forum Jump:
Forum Rules:
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is OFF
vB code is ON
Smilies are ON
[IMG] code is ON
< Contact Us - OdyClub >
Powered by: vBulletin Version 2.3.11
Copyright ©2000 - 2002, Jelsoft Enterprises Limited.
