prdufresne
Pseudo-Guru
Posts: 163 |
The in-dash DVD Player has been installed!
Okay, I've installed the following equipment in my Odyssey over the weekend:
- Innovatek FD-16TV In-dash Radio/TV Tuner, CD/DVD Player
- Innovatek TH-600D In-dash 6" TFT LCD Display
- Innovatek IN-104 Roofmount 10.4" TFT LCD Display
- Innovatek TA-02Y Amplified TV Antenna
The installation of the in-dash DVD and display was fairly simple, and following the i-VES instructions from HandA.com, the dash came apart very easily.
I purchased a wiring harness to connect to the factory wiring to avoid any cutting. I wired the TFT displays and amplifier to the Accessory power through the harness so that they would be disabled when the key is removed. The deck has connections for both accessory and battery, and it was connected as such.
I continued to follow the i-VES instructions to remove the passenger door trim, around both the front and sliding doors. I did find some differences though. It was not necessary to remove the seatbelt anchor bolt from the pillar, as the seatbelt was mounted to the seat. I was also successful at sliding the top pillar molding down and feeding my wires behind it without needing to remove it or the top seatbelt mounting bolt.
To provide better access to the roof, I removed the assistance handle in the rear as well as in the front. I wish I had gotten pictures of the van naked, but my wife had the camera at the time. I was able to use the i-VES mounting points to mount my display, but I had to drill an extra hole in the bracket that came with the display.
In addition to mounting the display, needed to mount the antenna along the top of the windshield. To gain access to run the cable, I removed the front overhead console (sunglass holder/dome light) and ran the cable along the ceiling and down the pillar on the right of the windshield. The antenna runs the full length of the windshield but high enough that you don't see it from inside and in the tinted area so you don't see it from outside.
Positives:
- Both 1-DIN items fit neatly into the dash
- TV gest excellent reception
- Antenna nearly invisible in it's mounting location
- All wiring and harnesses well hidden
- Roofmount display's dome lights wired easily into middle-passenger side dome light for common operation. (No cutting or soldering required).
Issues:
- The deck doesn't power down with the ignition even though this is a documented feature in the book. Tested this on the bench, there's something wrong, will probably have to replace it.
- Some of the documented i-VES installation procedures are out-of-date and there are some slight changes.
- Wiring harness is a little bulky and fell behind cup holders which won't close now. Have to open the dash to reposition the harness.
Resolutions:
- Obtain warranty replacement for deck or put the stock deck back in with an add-on DVD player connected to the CD-Changer input and installed in cup-holder slot.
And now, the pictures. Look for more before too long.
Attachment: two displays sm.jpg
This has been downloaded 494 time(s).
