OdyClub Forums - General Discussion New Page 1
Home  User CP   Register   Calendar   Member   F A Q   Search
OdyClub Forums : Powered by vBulletin version 2.3.11 OdyClub Forums > General Forums > 99 - 04 Odyssey > What did Honda fix on new 04 trannies
  Last Thread   Next Thread
Author
Thread Post New Thread    Post A Reply
shortwaver
Junior Member
Does anyone know what Honda did to the new trannies outside the vin range? Did they just factory install the oil jet or was there a design change?
thanks,
Shortwaver
Old Post 06-02-2004 03:34 PM
shortwaver is offline Click Here to See the Profile for shortwaver Click here to Send shortwaver a Private Message Find more posts by shortwaver Add shortwaver to your buddy list Edit/Delete Message Reply w/Quote
Wayne Lim
Banned
Re: What did Honda fix on new 04 trannies
quote:
thanks,
Shortwaver
There apparently was an internal design change.
Wayne
Old Post 06-02-2004 09:59 PM
Wayne Lim is offline Click Here to See the Profile for Wayne Lim Click here to Send Wayne Lim a Private Message Find more posts by Wayne Lim Add Wayne Lim to your buddy list Edit/Delete Message Reply w/Quote
Grayhound
Junior Member
Re: Re: What did Honda fix on new 04 trannies
quote:
Wayne
has anyone found any info supporting this?
Old Post 06-03-2004 03:06 AM
Grayhound is offline Click Here to See the Profile for Grayhound Click here to Send Grayhound a Private Message Find more posts by Grayhound Add Grayhound to your buddy list Edit/Delete Message Reply w/Quote
Daddy
Member
When I purchased my 04 EX-RES last week, the dealer told me that Honda has installed a larger capacity pump and they have increased the oil volume to avoid the problem.
I don't know if this constitutes a design change.
Old Post 06-03-2004 05:42 AM
Daddy is offline Click Here to See the Profile for Daddy Click here to Send Daddy a Private Message Find more posts by Daddy Add Daddy to your buddy list Edit/Delete Message Reply w/Quote
doopstr
Senior Member
Re: Re: Re: What did Honda fix on new 04 trannies
quote:
Check the FAQ that came with the recall notice.
__________________
04 Silver Ody EX-L NAV
Leather wrapped wheel.
Old Post 06-03-2004 04:21 PM
doopstr is offline Click Here to See the Profile for doopstr Find more posts by doopstr Add doopstr to your buddy list Edit/Delete Message Reply w/Quote
joec42
Senior Member
Do all 04's have the new design (upgraded pump?)? If not, what is the VIN or production date where the change occured? We're considering getting an 04, but the one on the lot with the color and options we want looks like it might have been there for a while...
Old Post 06-15-2004 04:58 AM
joec42 is offline Click Here to See the Profile for joec42 Click here to Send joec42 a Private Message Find more posts by joec42 Add joec42 to your buddy list Edit/Delete Message Reply w/Quote
shortwaver
Junior Member
Joec42,
the affected vin range is From VIN 5FNRL18..4B000001 thru 5FNRL18..4B051620.
Old Post 06-15-2004 02:27 PM
MobiusEntwine
Nom de Plume
I understand that the new trans has an internal modification. Odys out on the road with the unmodified transmissions are eligible for a modification kit to be installed. The recall to have your kit installed is being issued according to mileage or age of the vehicle, so that Honda service departments aren't overwhelmed having to work on every single Ody all at once.
I had my AT jet kit installed yesterday. It took 1.5 hours at Honda. It looks like they added a hose that goes into the top of the tranny where you would normally add AT fluid (the 17mm plug), and there is are a bunch of little brackets holding the new hose in place. The hose appears to come from the firewall side of the trans.
Last week, I installed an aftermarket trans fluid cooler. The hoses I installed were not touched by the kit. I have no idea how one is to add AT fluid with the kit installed, now that the filler hole is obscured by new hardware. My guess is that the kit has to be removed in order to add fluid.
It used to only require a 17mm socket and about 18 inches of socket extension to remove / replace the plug. And a breaker bar - the plug is probably the only bolt on the car that is really tight. Now it looks like one would have to remove all sorts of air ducts to get to all the bolts that hold the "jet kit" in place.
__________________
04 Odyssey LX, 108,000miles. Air Lifts, non-OEM AT Cooler, Mats, 2" Hitch, Softride 4-bike hitch rack, Thule / Rocky Mounts 5-bike roof rack, Kayak racks, Non-problem: side door track cover attachment clip failure. Fixed: clock light, rear window motors, PS wire.
Previous vehicles: 01 Ody LX, 3 other Hondas, 1 Toyota, 2 GM pos, 1 Ford pos.
Old Post 06-17-2004 05:45 AM
MobiusEntwine is offline Click Here to See the Profile for MobiusEntwine Click here to Send MobiusEntwine a Private Message Find more posts by MobiusEntwine Add MobiusEntwine to your buddy list Edit/Delete Message Reply w/Quote
adam1991
Senior Member
You don't have to remove the bolts that hold the jet kit in place. It'll pull out and go to the side all by itself, from what I remember.
But someone else here had the idea: just use the dipstick tube.
Old Post 06-17-2004 12:16 PM
adam1991 is offline Click Here to See the Profile for adam1991 Click here to Send adam1991 a Private Message Find more posts by adam1991 Add adam1991 to your buddy list Edit/Delete Message Reply w/Quote
Show Printable Version | Email this Page | Subscribe to this Thread
Forum Jump:
Forum Rules:
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is OFF
vB code is ON
Smilies are ON
[IMG] code is ON
< Contact Us - OdyClub >
Powered by: vBulletin Version 2.3.11
Copyright ©2000 - 2002, Jelsoft Enterprises Limited.
