stuberman
Member
Posts: 48 |
Overhead DVD/TV install 1999 Odyssey EX
I just finished installing an overhead DVD/TV system after reading others experiences on this site and wanted to share my experience and impressions.
1) Motivation
My family is again planning to drive to California this summer (almost 7,000 miles planned) and we wanted an entertainment system that wouldn't interfere with our comfort. I had built a little shelf that was strapped between the front seats to hold a 9" TV with DVD player. I had installed a Blitz audio adapter for the CD AUX input so we could listen through the van's sound system. We had considered portable DVDs (a problem if we had too many passengers that wanted to watch) and headrest displays (too much spaghetti and serves only one or two people) but realized that an overhead display would be clean, viewable by everyone in the rear and reduce the chance of people getting sick (from looking down rather than up).
2) Requirements
Affordable overhead system
DVD player
TV tuner (to check weather or news when stopped)
IR output for headphones
Audio output for connection to EX sound system (Blitz adapter)
AV input (optional) for Gamecube display
8"- 10" TFT display (big enough for all, not so big to interfere with rear view)
Widescreen 16:9 display (because so many DVDs are WS)
Two IR headphones
TV Antenna
Affordable install (or DIY if feasible)
Integrated system - DVD and TV tuner to be part of unit (don't want to take up space in the dash or under seats)
3) Search
Many local outlets (Best Buy, Circuit City) didn't have units that met enough of these requirements
www.autotoys.com had a few units but they were too expensive
I considered the Rosen, Pyle, Soundstream and Power Acoustik/Farenheit systems but this was going to run at least $700.
Trolled E-Bay and found an ideal compromise from Gooddeals18: Mobile Solutions MBN80.0 for $270
E-bay listing 5777790538
I chose this seller from New York because I was concerned about buying from a seller in China.
This unit can also be found listed as:
8" TFT CAR FLIP DOWN MONITOR TV DVD MP3 PLAYER JV8000
VS-8169 8" TFT CAR FLIP DOWN MONITOR TV DVD MP3 PLAYER
TView DVD 8000 8 INCH TFT LCD ROOF MOUNT MONITOR WITH BUILT IN DVD +TV
C-1007 8" TFT CAR OVERHEAD MONITOR W/ TV DVD PLAYER
The reason I called this a compromise is that the unit had a traditional 4:3 aspect ratio (like a normal TV). This particular unit also came with one set of IR headphones (I already had one pair that works with the system) and antenna. I also spent another $30 on a 3 year SquareTrade warrantee.
4) Install
- Mark and cut headliner
Based on advice from other posts on this board I measured 20.5" back from the sunglass holder to the front of the mounting plate. Then took a centerline measurement and traced the plate with a pencil. Asked the wife to validate the position (not too far back so kids don't have to look up too high) and ensure that screen wouldn't block rearview mirror. I then took a razor knife (mat knife) and cut 3/4" inside my line so I could adjust the plate but easily work under the headliner.
Mounting Plate
Cut headliner
Headliner view
Headliner wide shot
I was surprised how easy it was to cut the headliner. Once you get over the anxiety - it is a piece of cake.
- Remove Passenger Sun Visor
Next remove the passenger side sun visor and disconnect the connector for vanity lights. Two screws hold it in and a little twist to snake it out. This will make it easy to fish the wiring and avoid having to remove the headliner.
Sun Visor
- Remove Passenger side post cover
The piece of plastic just pulls off with a squeeze of your hands. I will run the wires down the channel.
Post Cover
Post with Cover Removed
- Remove Passenger side kick panel
This piece has a screw that attaches to a post in the carpet, a snap under the fuse box and a clip. After removing the plastic screw, just pull out with your hands. The is where I tap into power and ground the system.
Kick Panel
- Drop Glove Box
There are two plastic snaps that are in the inside of the glove box, just snap them out with a flat blade screw driver. This allows me to run the audio cables to the existing radio/Blitz.
Glove Box
Blitz Adapter
- Build wiring harness and fish
I decided that I would rather wrap the power and audio cables in a 7' duct that I found at Home Depot for $1.25 to protect the cables. I use a straightened wire coat hangar to fish the harness up from the windshield post. The hangar was easy to fish by pulling down slightly on the visor edge of the headliner. The audio cable that came with the unit was 79" long - but I really needed at least 9', so I bought a stereo cable (no video needed). The unit also came with a 79" power cable and noise filter. The grounding wire was long enough but the hot lead (red) needed an extra 18" (which I extended by soldering a lead - but I could also have used a splice connector).
Harness
Harness Pulled to Hole
- Optional Dome Lights
I ran the cables but didn't use them because the DVD dome light isn't really needed. The DVD manual is very poorly written and it took me a while to decipher the wiring for the lights. In the manual they are identified as Anode Cathode and Door Control. If you want to run connect to the dome lights, there are two screws and a slide that connect the dome light. You simply pull off the air deflector and light cover to get at them.
Dome Light
- Connect power and audio
I ran the audio cable carefully behind the glove box taking care that the glove box movement would not allow anything to catch on the cables. You can see the factory radio and the Blitz adapter.
I chose to splice into an existing circuit for power and use a groundling lug above the passenger side fuse box.
Extend harness down to behind glove box
Blitz connectors behind glove box
10mm grounding lug
Cabling above fuse block
- Affix Mounting Plate
Next I prepare the mounting plate. I use four #10 aluminum spacers to connect the plate to the roof beam.
Parts list:
Front: 2 x 3/4" spacers, 2 x 1.25" #8 sheet metal screws, 2 flat washers and 2 locking washers (start type).
Rear: 2 x 1" spacers, 2 x 1.5" #8 sheet metal screws, 2 flat washers and 2 locking washers (start type).
I mark the roof beam where I want the screws, use a center punch to make drilling easier. I put a steel angle bracket between the beam and the skin of the roof so I won't dent the roof when drilling.
After the holes are drilled I tape the spacers and screws to the plate with duct tape to hold them in place while working.
With this unit you must first connect all of the wires and then hang the DVD from the ceiling before you mount the plate.
After I connect the wires, I mount the plate.
I decided that the antenna would work best if we put a magnetic strip under the antenna plate and we would put it on the roof when needed. So instead of wirking the antenna cable under the headliner, I poked a hole in the front of the DVD base (where the vent screen is) and just let the antenna connector poke out for use when needed.
DVD hanging
Mounting Plate closeup
- Attach DVD
Shove the wires up through the slot in the plate and attach the DVD with the four screws supplied. Now replace all of the stuff I removed.
All set
- Enjoy
It Works!
5) Conclusion
The time to install this should be 2-3 hours after having all of the parts and preparing cables. I spent a little more time taking pictures, scratching my head, wasting time with the dome light and cleaning up some other stuff.
The total cost (not including the existing Blitz) was $350 including shipping and extended warrantee.
I was concerned about the quality on this 'no name' unit - but I am very impressed with the quality and functionality. The picture quality is superb and the viewing angle is great - everyone in the rear gets a great picture. Sound is quality is good and 'mute' function mutes internal speaker and external system. System has three input selects: DVD, TV and AUX. I like how the system shuts itself off when the display is flipped up. The display swivels and flips down beyond 90 degrees (perhaps 120 degrees). The color really matches the interior but the photos mislead.
The only complaints are:
Poor quality of the manual (not a big deal)
TV tuner auto program function is very slow and cumbersome
DVD/TV remote is not intuitive during initial set up
No regrets!
__________________
Stuart Berman
My blog
1999 Odyssey EX
