OdyClub Forums - General Discussion New Page 1
Home  User CP   Register   Calendar   Member   F A Q   Search
OdyClub Forums : Powered by vBulletin version 2.3.11 OdyClub Forums > General Forums > 05+ Odyssey > Fuel tank fill up woes. Gas tank never full at fill up.
Pages (4): [1] 2 3 » ... Last »   Last Thread   Next Thread
Author
Thread Post New Thread    Post A Reply
jmehren
Touring PAX Free Union
I cannot believe nobody has complained about the dumb gas tank. Every time I go to the gas station to fill up, it stops about 3 gal. short of full. I don't think anybody is aware of this. At least I haven't seen any complaint posts.
I have no children. I drive for a living. When I go to the gas station by want to make it worth my while. I am looking for maximum range with minimal amount of stops. I am sure this is not a California only issue.
And all of the Greenpeace activists who are going to complain about spilling fuel can go to a rainforest. I really don't want to hear it....... I'm not talking about it sloshing out of the tank. I'm talking about it not being anywhere near full. It decreases your overall range by almost 100 mi.. it must be some type of design flaw. There's no excuse for it being 3 gal. short of full.
Here is what Member "bhk" else said.
"Filled up today...........it was almost EMPTY, the light never went on! It took 17.355 gallons"
What???? Almost empty and it took just over 17 gal.??? I dare anyone to try and get 21 gal. into their tank. I don't think its possible.
I'm not saying the tank is not built to accept 21 gal.. I because think the design of the tank, its next to near impossible to get all the fuel in to full.
What you will find is the fuel pump just keeps clicking off. I have spent the time and forced the gas in. I went to 17 gal. when the first click came. I was able to get in 3 more gallons with extreme difficulty until I finally gave up. My hand was actually sore from the continual clicking of the pump.
This is so aggravating I can't see straight. And I know there is nothing I can do about it.
Jay M.
Touring Nav/Res
Old Post 06-14-2005 06:28 PM
jmehren is offline Click Here to See the Profile for jmehren Click here to Send jmehren a Private Message Find more posts by jmehren Add jmehren to your buddy list Edit/Delete Message Reply w/Quote
jjtindc
Member
I had the same thought. Filled up my tank for the second time over the weekend when the car was near empty. Range said it had approximately 20 miles left. First time I filled up we still had a quarter tank. It took just over 17 gallons. Remember thinking to myself that was a bit strange because the manual indicated 21 gallons. Getting a true fill up would be nice for the extra 80 miles or so.
__________________
2005 Touring w/ Nav & Res. Slate Green/Black. Mud Guards, Fenderwell Trim, Door Protectors, Air Deflector. Mr. Grille. Honda Cargo Tray. Weathertech Cargo Mat. Rubbermaid Cargo Organizer.
Old Post 06-14-2005 06:32 PM
jjtindc is offline Click Here to See the Profile for jjtindc Click here to Send jjtindc a Private Message Find more posts by jjtindc Add jjtindc to your buddy list Edit/Delete Message Reply w/Quote
Pahtoe
aka Wyeast (MIA)
It's highly unlikely you'll ever get a true "full-fill" on any vehicle. Because of the way the fuel pickup is designed (i.e. it's not set up like a kitchen sink drain in the bottom of the tank, it sits up off the bottom to keep you from sucking sediment all the time) plus you have residual fuel in the lines even after the fuel pump has gone dry.
Just about every car on the road is designed with a built in reserve after the gauge reads "E" and the fuel light comes on. On most cars this is about 1 1/2 to 2 gallons. Honda's traditionally have been a little generous with this, but I don't know if there's a specific amount on the '05 Ody like 3 gallons, since I've not run the tank down that far yet.
This is to prevent a whole host of people getting stranded on the road because they just don't pay close attention to their gauges. Also, it's to compensate for any inaccuracies in the gauge/sensor because you don't want the tank to run dry (like going uphill or on a funny corner) and not have the light go on if you've designed it to the ragged edge (2 oz left, only on level ground).
And how do I know about the first part? Ask my brother who ran his car bone dry (sucking air and having the car crap out on him in the middle of the road). According to the trip computer he *still* had a half gallon or a gallon left! (which is how he ran dry because he *thought* he could make it to a gas station on half a gallon)
--> Andy
(edit: Added in Italics)
Old Post 06-14-2005 06:46 PM
Pahtoe is offline Click Here to See the Profile for Pahtoe Click here to Send Pahtoe a Private Message Find more posts by Pahtoe Add Pahtoe to your buddy list Edit/Delete Message Reply w/Quote
egads
Senior Member
Your MID is wrong. Definitely set up to show less miles available than there really are. You don't want a very low tank in a fuel injected vehicle. And guess what? Topping off has nothing to do with rain forests. Two things happen. One is that fuel is forced into the charcoal canister and the entire evaporative recovery system causing failures and check engine lights. The second, especially in CA is that the fuel starts feeding back into the stations recovery system. So keep topping that tank, only you will loose. How can you make MPG calculations if you top off?
And guess what? the old days are over. Hug a tree for me!
Old Post 06-14-2005 06:55 PM
egads is offline Click Here to See the Profile for egads Click here to Send egads a Private Message Find more posts by egads Add egads to your buddy list Edit/Delete Message Reply w/Quote
William Wiles
Senior Member
Keep forcing fuel in and you will soon find out why there is an air bubble when the tank is full. The closed fuel system will suck fuel into the EVAP system and you will have to have it replaced....
Old Post 06-14-2005 10:17 PM
William Wiles is offline Click Here to See the Profile for William Wiles Find more posts by William Wiles Add William Wiles to your buddy list Edit/Delete Message Reply w/Quote
Chester_Lampwic
Senior Member
Typical, adjust from metric I never get more than 35 litres in my Corolla's 50 litre tank and 65 litres in my Ody tank which is 80+ litres.....
Old Post 06-14-2005 10:27 PM
Chester_Lampwic is offline Click Here to See the Profile for Chester_Lampwic Click here to Send Chester_Lampwic a Private Message Find more posts by Chester_Lampwic Add Chester_Lampwic to your buddy list Edit/Delete Message Reply w/Quote
GoodSonOdy
Good Son Member
I mananged to get over 20 gallons in mine but running the pump on slow. I found this out when I set the pump handle to slow while I went in to the store from some coffee and when I came back it had pumped over 20 gallans. And it Texas we do not have to recover things that you do in Calif. If you over fill it just goes all over the ground. I did not have any spills at all. My tank was full and my gauge stayed for a lot longer then normal.
__________________
2005 Ody EX-L OCEAN MIST BLUE 02/11/05 GoodSonOdy.com
2002 CR-V Ex 4WD BLUE 03/12/02
1965 Wife 03/31/00
Old Post 06-14-2005 10:28 PM
GoodSonOdy is offline Click Here to See the Profile for GoodSonOdy Click here to Send GoodSonOdy a Private Message Visit GoodSonOdy's homepage! Find more posts by GoodSonOdy Add GoodSonOdy to your buddy list Edit/Delete Message Reply w/Quote
jono
Senior Member
Re: Fuel tank fill up woes. Gas tank never full at fill up.
quote:
Congratulation!, you have ruined your evap canister. The charcoal inside it is now soaked with gasoline.
__________________
2004 Odyssey SSM EX
1993 Toyota Camry
Old Post 06-15-2005 04:51 AM
jono is offline Click Here to See the Profile for jono Click here to Send jono a Private Message Find more posts by jono Add jono to your buddy list Edit/Delete Message Reply w/Quote
jmehren
Re: Re: Fuel tank fill up woes. Gas tank never full at fill up.
quote:
Hmmmm...... A 21gal. tank and it always stops filling 17 gal. even when at 0 miles to go????? Now evap canister ruined over a 4 gal. shortfall???
I understand what you are saying, but I'm right back to the 4 gallon shortage.... I would understand if the gas pump cliicked off at 20.5 gal. or even 20.0 gal. then trying to top that off and ruining your evap canister..... but there is a huge differance between 17 gal. and 21 gal. when filling up from flat empty....
On another note, anybody who says it's bad for the motor/fuel pump by running your tank down to almost empty is wrong. Fuel pumps do not suck gas out from the top. They suck fuel from the bottom of your tank and pump the gas up. No matter what, you are going to suck sediment off the bottom of your tank. Whether or not your tank is completely full or completely empty.
Besides, hopefully the gas station you are using has decent fuel filters in-line and you also have the Honda fuel filter.
Oh, one more thing, I always drive cars under warranty. If I ever had a problem with anything like this it's going back to Honda.
But the sediment at the bottom of the tank is totally off subject. The issue here is, never being able to get a full tank in the Odyssey. I know for a fact I could get at least another 30 to 40 mi. with an extra 4 gal. (Give or take a little).
Old Post 06-15-2005 07:57 AM
Grand Total
Senior Member
If you damage your charcoal canister I don't think our warranty will cover it. The (2002) owner's manual says:
quote:
Stop filling the tank after the fuel nozzle automatically clicks off. Do not try to ‘‘top off’’ the tank, leave some room for the fuel to expand with temperature changes.
Your vehicle has an on-board refueling vapor recovery system to help keep fuel vapors from going into the atmosphere. If the fuel pump keeps clicking off even though the tank is not full, there may be a problem with this system. Consult your dealer.
__________________
2002 EX - Transmission replaced at 84,000km (52,000 miles). Sold at 104,000km.
Old Post 06-15-2005 01:11 PM
Grand Total is offline Click Here to See the Profile for Grand Total Click here to Send Grand Total a Private Message Find more posts by Grand Total Add Grand Total to your buddy list Edit/Delete Message Reply w/Quote
Ody-sama
Senior Member
As a sidebar, here in NJ we don't have self serve and you are at the mercy of the gas station attendents who tend to click their way to rounding up to the next dollar so there is no change to be dealt with on the bill and the tip.
Anyhow, so yesterday my wife asked this attendent at the Mobil to fill-er-up and yes it stops between 17 and 18 gallons. But the idiot forgot put the cap on altogether! It was left dangling and my wife also did not notice it until reaching home.
Luckily there are no scratches on the body from the cap but no fuel seemed to have sloshed out. Anyone know if this would have caused any problem on a dry sunny day? Thanks.
__________________
___________________
05 Ody EXL Desert Rock Metallic/Ivory Navi + Res
95 Nissan Maxima
Old Post 06-15-2005 01:59 PM
Ody-sama is offline Click Here to See the Profile for Ody-sama Click here to Send Ody-sama a Private Message Find more posts by Ody-sama Add Ody-sama to your buddy list Edit/Delete Message Reply w/Quote
William Wiles
Senior Member
21 gallons is the volume of the tank, not the volume of usable gas. Other things are involved like expansion of the gas, the evap system. Also tha accuracy of the pump is not necessarily that great. I made a formal complaint once when I put 14 gallons in a 12 gallon tank at a cut rate station. If you force the tank full as the gas warms up and expands it will force gas to the EVAP and ruin it.
Old Post 06-15-2005 04:18 PM
Steve P
Senior Member
quote:
What? You TIP the gas station attendant?
__________________
Current Hondas:  2010 Odyssey Touring, Polished Metal Metallic;2005 CR-V EX-SE, Pewter Pearl
Previous Hondas: 2001 Odyssey EX-NAVI, Starlight Silver; 1997 Accord EX-L Forest Green; 1992 Accord EX, White; 1982 Accord DX hatchback, Silver
Hobby:  geocaching
Old Post 06-15-2005 04:40 PM
Steve P is offline Click Here to See the Profile for Steve P Click here to Send Steve P a Private Message Find more posts by Steve P Add Steve P to your buddy list Edit/Delete Message Reply w/Quote
Pahtoe
aka Wyeast (MIA)
The sediment remark is not off subject. The point of it was because of the way the fuel pickup is designed there is fuel left in the tank even when you *think* you've run empty. This was also the point of my comment about my brother "running out of gas" even though the trip computer (and subsequently the amount of gas he was able to pump in later) both agreed he had fuel left even through the car stopped.
Did you try to fill and get 17gal when the van had stopped bone cold dry, or just when the gauge read Empty? I guarantee you there is still fuel left the moment the needle drops to "E". Even my old '60's Chevy had a reserve built in after the gauge ran empty (at 10mpg, thank God! )
William also makes a valid comment about there being some air on top because of expansion/sloshing.
In Oregon we're also at the mercy of the pump jockeys, and more than once I've had fuel slosh out past a vented cap because the guy was overeager with the topping off. One comedic incident occured back when I had that old Chevy. The filler was behind the license plate, and at a shallow angle, which meant that when the guy tried to overfill, it literally vomited gas right back at him!
Needless to say he didn't try to top off my car after that.
--> Andy
Old Post 06-15-2005 04:52 PM
egads
Senior Member
So what part of the MID is wrong don't you get? Just because it says you have only 20 miles or even 0 miles left doesn't mean your tank is completely empty. You seem like the kind of guy who is never going to be happy until you run the thing completely dry and then fill it. If you did that you might get 19.5 in there. It reads empty exactly where Honda wanted it to. This works for the majority of the owners. Having a large margin of fuel left has saved my a** more than once. I do not want it redesigned to please you. And how do you figure mileage if you top off? By the way, topping off is illegal in our state.
Old Post 06-15-2005 06:02 PM
Show Printable Version | Email this Page | Subscribe to this Thread
Forum Jump:
Rate This Thread:
Forum Rules:
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is OFF
vB code is ON
Smilies are ON
[IMG] code is ON
< Contact Us - OdyClub >
Powered by: vBulletin Version 2.3.11
Copyright ©2000 - 2002, Jelsoft Enterprises Limited.
