OdyClub Forums - General Discussion New Page 1
Home  User CP   Register   Calendar   Member   F A Q   Search
OdyClub Forums : Powered by vBulletin version 2.3.11 OdyClub Forums > General Forums > Kids and Safety > Marathon, Roundabout and SnugRide in 05
  Last Thread   Next Thread
Author
Thread Post New Thread    Post A Reply
dukefan
Member
We have an 05 EXL-RES Ody and just had our 3rd daughter. We currently have Britax Marathon (3 1/2 yr old daughter sits here) and Britax Roundabout (2 yr old daughter sits here) carseats in the 2nd row captains chairs and the baby's Graco SnugRide infant carrier base is in the middle of the 3rd row. We have the PlusOne seat removed to allow for access to place the baby in the middle of the 3rd row. This current configuration of our carseats is a pain! I hate having to lug the baby in her infant carrier back to the 3rd row. We have seriously considered (and will likely try) placing the Marathon and Roundabout carseats in the 3rd row and putting the baby's infant carrier in one of the 2nd row captain's chairs, but the reason we have not done this yet is because of the lack of LATCH in the 3rd row- there is only one in the center, thus the 2 large carseats will not be LATCHed in the 3rd row. We think that this will be unsafe.
I have seriously considered trading this van (although I really really like it!) for a Toyota Sienna LE-8 to have all 3 children in the 2nd row with their carseats all safely LATCHed. I don't want to give up the features that I enjoy on the Ody such as dual sliding doors, etc. Why didn't the Honda design the van with more than 3 LATCH seating options? It is a family van!!!
Any advice is welcome. Thanks so much.
Old Post 10-04-2005 05:43 PM
dukefan is offline Click Here to See the Profile for dukefan Click here to Send dukefan a Private Message Find more posts by dukefan Add dukefan to your buddy list Edit/Delete Message Reply w/Quote
shellebelle
vroooooom...
Installing a car seat with LATCH is just as safe as with a seat belt. The LATCH system is just more streamlined and standardized for parents, and therefore has a lower chance of being misued. Britaxes are extremely easy to install with a seatbelt, so that's a plus for you.
However, the outboard seats in the third row lack a top tether, which is really a good idea to use with forward facing car seats. US seats are certified to be used without a top tether, but have to pass a less-strict head excursion limit when used this way. Your Marathon MUST be tethered once your 3.5yo hits 50lbs.
How about this:
Remove one captain's chair. Install a Britax on the remaining one. Then, install the SnugRide on the third row bench behind where the captain's chair used to be. Install the remaining Britax in the center, with LATCH if you prefer, and take advantage of the top tether. So long as the child in the third row with the baby doesn't poke or jab, you should have plenty of room to get baby in and out.
Getting the SnugRide next to one of the other car seats may be tricky. You may need to install the third row Britax with the seat belt so that you can move it as far away from the SnugRide as possible. If you have trouble with this, your friendly local Child Passenger Safety Technician can help you out.
Michelle
Old Post 10-05-2005 05:54 AM
shellebelle is offline Click Here to See the Profile for shellebelle Click here to Send shellebelle a Private Message Visit shellebelle's homepage! Find more posts by shellebelle Add shellebelle to your buddy list Edit/Delete Message Reply w/Quote
Manny
Junior Member
We have three also. I have the 4 year old in the back with an Advantage. He's on the right side. There's a fabric loop (made from the same material as the tether strap) with a metal piece that I wrap around the third-row seat anchor that I use to tether the rear of the child seat. Strictly an extra precaution, the seat is pretty stable if I sit on the seat when I put on the seat belt.
We have a Roundabout on the left middle for the 2 year old, and then a Graco on the right. We moved it to the middle, so we can get in the back and buckle the 4 year old in.
LATCH is great becuase it makes installation relatively idiot-proof, but its no safer than a properly installed seat with the seat belt.
__________________
'03 Ody EX-L Starlight Silver with IconDVD
'01 Audi S8 Silver
Old Post 10-08-2005 11:24 PM
Manny is offline Click Here to See the Profile for Manny Click here to Send Manny a Private Message Find more posts by Manny Add Manny to your buddy list Edit/Delete Message Reply w/Quote
shellebelle
vroooooom...
quote:
Unfortunately, this piece isn't designed to be used when the car seat is forward facing. I have serious doubts about it'd holding in a crash, and then the tether clip turns into a nice hard projectile
Old Post 10-09-2005 06:19 AM
Manny
Junior Member
Its should hold up as well as the tether, which is the same material. If the whole third seat comes off the anchor, the car seat stays attached. Even if the piece became a projectile, which I seriously doubt if you pull it tight, its below the seat and would go in the same direction as that stroller in the back... Your seat belt is doing all the work in a crash anyway..
Location-wise the tether ends up in the same location as the tethers for the captain's seats.. (in the 03 models anyway).
__________________
'01 Audi S8 Silver
Old Post 10-10-2005 12:47 AM
shellebelle
vroooooom...
It's not so much as the webbing as the stitching holding the pieces together. We have no way to tell if they're as strong as the stitching on the tether (if there is any, the attachment is concealed). If the D-Ring breaks, there is the potential for the tether clip to come flying over the top of the car seat and nailing someone in the face or eye.
Either way, your manual says to only use the attachment with a rear facing car seat (pg 23). Use it forward facing at your own risk.
Old Post 10-10-2005 02:01 AM
caviller
WTB More Moderators
I agree with Michelle. Britax instructions are pretty clear- the D-ring strap is only for use rear-facing. It's quite likely it hasn't been crash tested for front-facing use, or worse, it was tested and failed.
No, it won't completely compromise the seat installation in a crash if a top-tether was incorrectly used. In fact, seats must pass minimum requirements even without a top tether strap of any kind. Even so, top-tethers do improve crash performance of a front facing carseat; seatbelts do not adequately restrain the top of the child restraint. Almost every seat on the market must use a top tether to meet the stricter head excursion requirements (The discontinued Fisher Price Futura is the only exception I know).
The risk is that the top of the seat could move farther forward in a crash than if a tether had been used. Similarly, if a tether was to break in a crash it could also allow more forward excursion of the head. This increases the risk that the child's head could strike a pillar, seat back or other hard interior surface. Overall, it's probably not a serious misuse, but why not do it correctly according to the manufacturer's instructions?
__________________
Are Your Kids Safe? - www.Seatcheck.net
2006 Silver EX-L w/fogs-muds-sub-ipod musiclink, replaced 2001 GG LX at 5yr/43k
Old Post 10-10-2005 03:43 AM
caviller is offline Click Here to See the Profile for caviller Click here to Send caviller a Private Message Visit caviller's homepage! Find more posts by caviller Add caviller to your buddy list Edit/Delete Message Reply w/Quote
caviller
WTB More Moderators
Also, you will not be able to use the lower anchor component of LATCH beyond 40 or 48 pounds in any case. That is the maximum allowed by Honda and Britax. After that, you will have to switch back to the seatbelts for installation anyway.
As Michelle said, unless the use of LATCH results in a more secure installation, it is no safer than a seatbelt. Generally, you would use whichever one provides a better fit if you are capable of installing them either way.
__________________
Old Post 10-10-2005 03:51 AM
Show Printable Version | Email this Page | Subscribe to this Thread
Forum Jump:
Forum Rules:
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is OFF
vB code is ON
Smilies are ON
[IMG] code is ON
< Contact Us - OdyClub >
Powered by: vBulletin Version 2.3.11
Copyright ©2000 - 2002, Jelsoft Enterprises Limited.
