cnn
Senior Member
Posts: 1088 |
Interesting Fuel Mileage Data between 65 vs 78 mph
HYPOTHESIS: Is fuel mileage worse at 78mph versus 65 mph?
(I could not drive at 55mph for fear of being rear-ended! Also above 80 mph is risky for getting speeding tickets! So the data you see is from between 65 vs 78 mph).
2001 Ody LX 65K miles
Omaha, NE- Chicago trip (460 miles/each way)
-New spark plugs Bosch Platinum
-2 adults & 4 kids (under 13 yrs old): Weight about 550 lbs total
-Standard cargo: one ice cooler and 6 bags of baggage of clothes
-Tires 40 psi
-AC on entire trip
-New Brakes Front, so no brake drag or problems
-Alignment done 2 weeks ago.
-Weather 60F, non-windy (at most 5 mph wind)
-Gas is Octane 89, fill and stop filling gas at first “click”.
-Cruise Control used 90% of the time as much as condition allows safe use of cruise control.
-I “zeroed” the odometer at each fill-up to ensure accurate readings between fill-ups
EASTBOUND:
65 mph 288 miles/12.1 gallons = 23.80 mpg
75 mph 221 miles/9.41 gallons = 23.48 mpg
WESTBOUND:
78 mph 381 miles/16.09 gallons = 23.68 mpg
My point is between 65 mph and 78 mph, there is very little drop, if any, in fuel economy (in contrast to government data which indicates a drop of approx. 7 mpg or so between 65 and 78 mph)
MY “CONCLUSIONS”
1. Government data may have been obtained from cars from 80’s and 90’s, which were possibly less aerodynamic.
2. 2001 Honda Odyssey has very good aerodynamic shape (almost like an airplane tip) and the fuel mileage may be different than this:
http://www.fueleconomy.gov/feg/driveHabits.shtml
I suspect the “significant” drop happens after 80 mph for Ody (but I cannot prove it because of speed limits!).
Of course, an airplane has a differnet fuel mileage curve.
3. The drop in fuel mileage between 65 vs 78 mph was negligible, if any. (BTW I do not have 55 mph data, reason as above).
4. I did this experiment simply to prove my point. I do NOT encourage speeding, please follow posted speed limits.
***NOTE: This is as good as data set as I can get.
*** Also, the shape of the fuel mileage curve is different for each vehicle.
I am looking for sharing highway Fuel Mileage data in an honest fashion so we can all learn about Ody characteristics.
Anyone with another set of data will be appreciated!
__________________
cnn: 2007 Odyssey LX 30K miles
