OdyClub Forums - General Discussion New Page 1
Home  User CP   Register   Calendar   Member   F A Q   Search
OdyClub Forums : Powered by vBulletin version 2.3.11 OdyClub Forums > General Forums > 99 - 04 Odyssey > new owner w/ many questions
  Last Thread   Next Thread
Author
Thread Post New Thread    Post A Reply
groot
Junior Member
Hello all, I just purchased a 2000 Odyssey EX, my first entry into the Odyssey world. After giving the van a thorough cleansing, I came up with several questions. The search tool on the forum was very useful and most of my questions have already been answered, here are a couple that still remain:
Are there supposed to be plastic caps to cover the seat anchors when you remove the middle seats? If so, where is the cheapest place to purchase these caps? Does anyone have the part numbers by any chance?
The rubber/foam around my steering wheel has separated from the inside ring so that I can twist it back and forth around the steering wheel. This makes my grip on the steering wheel very loose and it is doubtful that installing an aftermarket steering wheel cover would solve the problem. Is there a quick fix for this?
Do you have to remove the dash to replace the cruise control lights like you do for the clock light, or does the cruise control switch pop right out?
Is there any consensus as to best liner for the area behind the third seat?
Thanks in advance for all your help. Hopefully, after getting my hands dirty, I will be able to return the favor to others.
__________________
2000 Odyssey EX
Old Post 08-28-2006 10:28 PM
groot is offline Click Here to See the Profile for groot Click here to Send groot a Private Message Find more posts by groot Add groot to your buddy list Edit/Delete Message Reply w/Quote
vpp1999
Senior Member
See this link for striker covers:
http://www.slhondaparts.com/browse....;ViewParts=true
No real good repair for the delaminated steering wheel that I've had success with. I found a good replacement for my Civic steering wheel on ebay. I believe a read a post of someone having success by inserting epoxy glue with a syringe needle. You may want to do a search for thqat post.
Search on the cruise control light, I know there have been several posts on it.
No opinion on the best liner.
__________________
1999 Odyssey LX >126k miles (original tranny)
1996 Accord EX Wagon >228k miles
1989 Civic LX >246k miles ('95 Vtec motor swap @ 190k)
Old Post 08-28-2006 11:44 PM
vpp1999 is offline Click Here to See the Profile for vpp1999 Click here to Send vpp1999 a Private Message Find more posts by vpp1999 Add vpp1999 to your buddy list Edit/Delete Message Reply w/Quote
honus
Pretend Honda Tech
Some answers\comments
Take a look at Hand A Accessories
http://www.handa-accessories.com/odyint01.html
Striker Covers:
You'll notice the link in the response above that the item #8 is a 3/4 cover. Unless I do not see it, it is not easy to tell how the numbered items merry-up with the parts numbers on the next page.
Oddly, they do not make a full cover when you remove a second captain's seat. I purchased two 3/4 covers and cut off 1/3 of it and then put 2 of them together to cover the entire anchor when the chair is removed. The 3/4 cover is part numer 83309-S0X-A00ZX (the "X" depends on the color) "Cap, seat striker cover C". The 83308-S0X-A00Z"X" is the smaller cap cover number. They can be found at the above link.
Steering Wheel:
There are steering wheel "covers" at the above site but I'm not sure a new wheel or fix for your issue.
Liner:
The trunk\bed liner is referred to as a "cargo tray and can be found at H and A for about $70. I wish I bought mine earlier in the Ody's life. Fruit punch doesn't come out of the carpet easily enough.
__________________
2002 Honda Odyssey EXL - 186K (Orig. Tranny)
KYG GR2 Shocks, Honda struts & springs, Honda trans. cooler & heavy duty PS cooler, Thule Cascade XT 1700, Honda hitch and Thule 915 Roadway, Redline Syn-Oil & Water Wetter, Michelin Harmony tires
2003 Honda Accord EXL - 227K (2nd Tranny at 180K)
Redline Syn-Oil & Water Wetter, Michelin MXV4 Primacy tires
2000 Honda Masters Mower HR215 5.0, Redline Syn-Oil
1999 Honda Generator EG5000, Redline Syn-Oil
Old Post 08-29-2006 01:51 AM
honus is offline Click Here to See the Profile for honus Click here to Send honus a Private Message Find more posts by honus Add honus to your buddy list Edit/Delete Message Reply w/Quote
groot
Junior Member
thanks for the help. odd that honda does not make a full large striker cover. has anyone found an aftermarket outfit that has one available?
__________________
2000 Odyssey EX
Old Post 08-30-2006 07:46 PM
Show Printable Version | Email this Page | Subscribe to this Thread
Forum Jump:
Forum Rules:
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is OFF
vB code is ON
Smilies are ON
[IMG] code is ON
< Contact Us - OdyClub >
Powered by: vBulletin Version 2.3.11
Copyright ©2000 - 2002, Jelsoft Enterprises Limited.
