Jackson
Senior Member
Posts: 537 |
Exceeding the safe limit.
You will be above the recommended Maximum Total Trailer Weight. Boat with no trailer or options is 3000 lbs already. http://www.wakeworld.com/boats/getb...roductID=200111 Recommended Max Total Trailer Wt with 4 occupants is 3,050 lbs. The boat already weighs 3000 lbs. That is with no trailer or camping gear. A stronger tow vehicle would be safer and do a better job.
See the attached file from the 2006 Odyssey Owners Manual and the data from the same source below:
"Maximum Total Trailer Weight
Equipped with transmission cooler
and power steering fluid cooler
Occupants
1 3,500 lbs (1,580 kg)
2 3,350 lbs (1,520 kg)
3 3,200 lbs (1,450 kg)
4 3,050 lbs (1,380 kg)
5 2,900 lbs (1,310 kg)
6 2,750 lbs (1,250 kg)
7 2,600 lbs (1,180 kg)
7 Touring Model only 1,550 lbs (700 kg)
8 650 lbs (290 kg)
1: Including driver. Based on 150 lbs (70 kg)
per occupant.
2: See page 315 for information about fluid
coolers.
3: LX, EX and EX-L models
4: Touring model
To achieve a proper tongue load,
start by loading 60 percent of the
load toward the front of the trailer
and 40 percent toward the rear, then
re-adjust the load as needed.
Gross VehicleWeight Rating
(GVWR):
The maximum allowable weight of
the vehicle, all occupants, all cargo,
and the tongue load is 5,952 lbs
(2,700 kg).
Gross AxleWeight Rating
(GAWR):
and the tongue load must not
exceed:
On all models except U.S. Touring
model : 2,833 lbs (1,285 kg) on the front
axle, and 3,197 lbs (1,450 kg) on
the rear axle.
On U.S. Touring model : 2,877 lbs (1,305 kg) on the front
the rear axle.
Gross CombinedWeight Rating
(GCWR):
the fully loaded vehicle and trailer
is 8,410 lbs (3,815 kg)"
Attachment: page313 honda odyssey 06b.gif
This has been downloaded 41 time(s).
