OdyClub Forums - General Discussion New Page 1
Home  User CP   Register   Calendar   Member   F A Q   Search
OdyClub Forums : Powered by vBulletin version 2.3.11 OdyClub Forums > General Forums > 99 - 04 Odyssey > Spare Tire- I am ashamed of Myself
  Last Thread   Next Thread
Author
Thread Post New Thread    Post A Reply
wild willy
Senior Member
I have had my van since oct of 2003 and never looked for the spare. We are leaving for vacation and my tires are no longer new, but still have some life. So I decided to check the spare...
Where the fock is it??? I looked under, inside and every fockin where...
So I did what every man dreads..I opened the glove box and took out the manual.......
And sonofabitch.....isn't that sucker in the floor. So I figured I'd check the pressure and be done with it......Well not going to happen..
This thing is a pain in the ass to get to (when you got kids **** in the van) and the valve stem faces down......Not too bright. So I took it out to find it only had 25psi and pumped her up. And then tried to get it back in and lined up so the bolt would go in...Another not so godd of an Idea Honda...
After my frustration went away....I thought...not a bad place to have a spare..Then it hit me...When on vacation with 6 people and luggage, if you do have a flat..where in the hell are you going to put the flat 16 inch wheel and tire
Have a good day..I am sure this is not new to 95% of you
__________________
King of Custom Pedals
04 Odyssey (9.67mpg mix) 27mpg Highway- Go figure
02 Altima SE (22mpg City)
91 MR2
04 GTO 6MT (Beater) 17.5mpg City)
^^^Gone
Old Post 07-04-2007 05:28 PM
wild willy is offline Click Here to See the Profile for wild willy Click here to Send wild willy a Private Message Find more posts by wild willy Add wild willy to your buddy list Edit/Delete Message Reply w/Quote
odcouple2
Senior Member
Re: Spare Tire- I am ashamed of Myself
They provided a bag for you to store your flat in...
Old Post 07-04-2007 09:35 PM
odcouple2 is offline Click Here to See the Profile for odcouple2 Click here to Send odcouple2 a Private Message Find more posts by odcouple2 Add odcouple2 to your buddy list Edit/Delete Message Reply w/Quote
Jerry O
CHAIRMAN OF THE BORED
Howzabout on the roof?
Jerry O.
__________________
UFCW Retired
UNION, YES!!!
(The labor movement, the folks who brought you the weekend)
2006 Ocean Mist Metallic EX-M(Mouse fur) + WeatherTech cargo mat, Mr. Grille, Dashhugger dashcover, ScanGauge, Magellan GPS, Acura MDX wheels, 245/50-18 Yokohama ADVAN S.4 tires and AirLifts. Also, a few "faux" items, such as "dual" exhaust outlets, smoked plexiglass foglight hole fillers, and miscellaneous homegrown ground effects items, topped off by an "R" next to the "Odyssey" on the rear liftgate.
2001 GG LX-R(revised), still in the family. Now at 85K miles.
1994 Dodge Caravan SWB w/3.0, still in the family w/ over 150K miles
Dyson DC17 vacuum cleaner (to maintain the "dash rug")
John Deere 14PZ mower (push-it-yourself)
Old Post 07-04-2007 11:45 PM
Jerry O is offline Click Here to See the Profile for Jerry O Click here to Send Jerry O a Private Message Find more posts by Jerry O Add Jerry O to your buddy list Edit/Delete Message Reply w/Quote
honus
Pretend Honda Tech
I knew it was located there but....
I did the exact same thing last week on my 2002 (132K) for the first time only I wasn't going on vacation. What a pain in the azz without any kids or any luggage in the van.
__________________
2002 Honda Odyssey EXL - 186K (Orig. Tranny)
KYG GR2 Shocks, Honda struts & springs, Honda trans. cooler & heavy duty PS cooler, Thule Cascade XT 1700, Honda hitch and Thule 915 Roadway, Redline Syn-Oil & Water Wetter, Michelin Harmony tires
2003 Honda Accord EXL - 227K (2nd Tranny at 180K)
Redline Syn-Oil & Water Wetter, Michelin MXV4 Primacy tires
2000 Honda Masters Mower HR215 5.0, Redline Syn-Oil
1999 Honda Generator EG5000, Redline Syn-Oil
Old Post 07-05-2007 12:02 AM
honus is offline Click Here to See the Profile for honus Click here to Send honus a Private Message Find more posts by honus Add honus to your buddy list Edit/Delete Message Reply w/Quote
odybertie
Member
Alternative location
Imagine it's pooring with rain, you're loaded to the hilt from a camping weekend and you have a flat. On most vehicles you have to unload all, yes ALL, the stuff out of the back of the car to access the spare. Remember, it's pooring down, so all your stuff gets wet in addition to you getting wet replacing the spare. This would not be the case with the Ody as the spare tire is always accessible even if you have the back fully loaded up. True, it's akward to get to behind the front seats, but Honda could not put it anywhere else with the space requirements of the magic seat. Placing it in the back is automatically excluded due to the magic seat which is a feature we all appreciate. Anyway, reading your manual you would see that not only is a bag provided for the flat, but there is a mounting location where you can fix your full size flat in the back to make it secure in case of an accident. See the little carpet flap about 2/5 of the way from the left, just as you go over the lip from the magic seat well to below the seat when it is opened up. You reuse the bolt that holds the spare down to fix it securely in the back.
__________________
Odybertie
02 EX SS
Old Post 07-05-2007 09:27 AM
odybertie is offline Click Here to See the Profile for odybertie Click here to Send odybertie a Private Message Find more posts by odybertie Add odybertie to your buddy list Edit/Delete Message Reply w/Quote
papa's ody
Senior Member
Yep, problem has been fixed in 05+ ... now the spare is in the back sidewell .... which you can't open unless you unload everything in the rear.
Oh, the flat one ... simple, leave everything in the rear compartment on the road and put the tire in the rear storage area.
What do these people think ? We buy a van and LEAVE IT EMPTY ?
I guess PAX was the solution for that one.
(I can hear the PAX people laughing now)
__________________
2005 Ody EX-L Ocean Mist
1991 Honda Civic Wagon
Old Post 07-05-2007 06:16 PM
papa's ody is offline Click Here to See the Profile for papa's ody Click here to Send papa's ody a Private Message Find more posts by papa's ody Add papa's ody to your buddy list Edit/Delete Message Reply w/Quote
oddyose
Junior Member
I thought the bag was to put your wife in when you stick her on the roof rack, as long as she's not over the weight limit. At least she's dry. She'll get over it eventually. Then roll the flat tire over to the passenger door--easy in and out. The wife gets to come back in when you get the tire fixed. No problem, right?
__________________
01 GG EX
-- Hydroedge tires
-- Optima Red Top Battery
-- Mobile 1
-- Zainoed twice a year
Chrysler Cirrus
Le Baron Convertable
Old Post 07-06-2007 12:04 AM
oddyose is offline Click Here to See the Profile for oddyose Click here to Send oddyose a Private Message Find more posts by oddyose Add oddyose to your buddy list Edit/Delete Message Reply w/Quote
firemann1
Senior Member
Thanks for the reminder! It's been a while since I checked the air pressure in the spare of our 2002 Ody.
A few random thoughts about the spare tire storage location . . . .
It seems as if the spare tire could be engineered to be in a nice accessible location - but then it would be taking up other more valuable space. Let's see, there might be enough room for the spare tire to stand up placed between the two front seats. Not sure how it could be anchored but it would be less hassle to get it out if needed. One big disadvantage, it would be taking up valuable space.
I've had several vehicles which have the spare mounted under the vehicle with a cable and crank device. These systems work but are also a hassle. Checking the air pressure in these means raising the vehicle or getting dirty.
I absolutely agree. The location of the spare in the 2nd gen Ody's has it's disadvantages. But if I put on my engineer's hat, I'm unable to find a better location.
Now off I go to check the air pressure of the spare tire.
__________________
'02 Odyssey EX (Ours)
'09 Fit (Hers)
'03 Accord EX V6 Sedan (His)
'05 CRV (Son #2,)
'88 Accord 5M 2D Coupe (Son #3)
Old Post 07-06-2007 04:51 AM
firemann1 is offline Click Here to See the Profile for firemann1 Click here to Send firemann1 a Private Message Find more posts by firemann1 Add firemann1 to your buddy list Edit/Delete Message Reply w/Quote
wild willy
Senior Member
I checked my sister's o4 spare yesterday..it too had 20lbs or so of pressure. This removal went much smoother than the first. I am gonna have to say after further thought.....Not a bad place at all for a spare. I too had several vehicles with the spare under the car......Not much fun to change....
__________________
91 MR2
^^^Gone
Old Post 07-06-2007 12:58 PM
OdyinNH
Senior Member
I think the spare placement on my 2k Ody is about the best you can ask for. It stays clean and free of rust assuming a child hasn't spilled multiple drinks in there. I had Caravans with the tire underneath the rear, what a nasty place to get it down from assuming the mechanism still works. Also, I looked under there one day and the tire was missing, just a rusty ended cable sitting there. Imagine if you were on the side of the highway only to find out you lost your spare 100 miles ago. Luckily I was in my driveway.
__________________
Mike
2000 Odyssey LX
Trans at 82k -- Tru-cool trans cooler
DIY Timing Belt at 104k
Hidden Hitch & Airlift 1000's
Old Post 07-06-2007 08:37 PM
OdyinNH is offline Click Here to See the Profile for OdyinNH Click here to Send OdyinNH a Private Message Find more posts by OdyinNH Add OdyinNH to your buddy list Edit/Delete Message Reply w/Quote
Jerry O
The trick of wrapping the spare in a big beach towel and storing it in the valve-up position without the hold-down screw makes any use of the spare (air checks, flat replacements) much easier. When one considers how often one actually USES the spare, it is a pretty good location.
Jerry O.
__________________
UFCW Retired
UNION, YES!!!
Old Post 07-08-2007 04:34 AM
wild willy
Senior Member
quote:
Jerry O.
Good Idea Jerry!! I thought about flippin it...I guess I'd just put the big dog dish on the bottom then??
__________________
91 MR2
^^^Gone
Old Post 07-08-2007 12:40 PM
Jerry O
Our '01 did not have a dog dish, but underneath would be fine.
Jerry O.
__________________
UFCW Retired
UNION, YES!!!
Old Post 07-09-2007 04:31 AM
wild willy
Senior Member
Jerry O.
Makes a great cereal bowl on vacation for the wife
__________________
91 MR2
^^^Gone
Old Post 07-09-2007 12:53 PM
findude
Member
I check our spare tire pressure every couple of months, so I've gotten pretty good at it. Without getting into the issue of whether this is a good location or not, here's what I do:
--Slide the front seats forward a bit, if you recline them much, you may have to shift them more upright.
--Slide the middle seats all the way back.
-Remove the floor mat by folding it from each side toward the center. Then you flip it over into the space between the two middle row seats (assuming you configure them that way).
--Lift the cover and fasten the handy clip to the grab bar on the back of the driver's seat to hold it open.
--Remove "dog dish" (gotta love that term--new to me)
--Undo the bolt after noting its position.
--Lift the spare out of the well (I then take it out of the car to inflate it)
--Replace the spare and screw the bolt back in (a flashlight can help to make sure you have it aligned right.
--Close up.
It is important to do this periodically, as the spare will typically lose several pounds of pressure over just a couple of months.
Good luck!
__________________
2002 Odyssey EX/L RES
Old Post 07-11-2007 11:18 PM
findude is offline Click Here to See the Profile for findude Click here to Send findude a Private Message Find more posts by findude Add findude to your buddy list Edit/Delete Message Reply w/Quote
Show Printable Version | Email this Page | Subscribe to this Thread
Forum Jump:
Forum Rules:
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is OFF
vB code is ON
Smilies are ON
[IMG] code is ON
< Contact Us - OdyClub >
Powered by: vBulletin Version 2.3.11
Copyright ©2000 - 2002, Jelsoft Enterprises Limited.
