OdyClub Forums - General Discussion New Page 1
Home  User CP   Register   Calendar   Member   F A Q   Search
OdyClub Forums : Powered by vBulletin version 2.3.11 OdyClub Forums > General Forums > 05+ Odyssey > front fender liner problem on '07
  Last Thread   Next Thread
Author
Thread Post New Thread    Post A Reply
scrawshaw
Junior Member
Any else notice big gaps between the liner and the metal on the inside of the fender wells at the outside edge of the liner? Another one in the Honda lot had the problem too. I feel like it is going to cause corrosion problems in the Winter, when snow gets between the liner and the inside of the fender. Not sure how to fix it.
Old Post 08-06-2007 02:17 AM
scrawshaw is offline Click Here to See the Profile for scrawshaw Click here to Send scrawshaw a Private Message Find more posts by scrawshaw Add scrawshaw to your buddy list Edit/Delete Message Reply w/Quote
mjody
Is it foggy in here???
Not going to happen. There are always going to be gaps like that, any model, any manufacturer. Plastic will twist and warp over time.
Old Post 08-06-2007 02:25 AM
mjody is offline Click Here to See the Profile for mjody Click here to Send mjody a Private Message Find more posts by mjody Add mjody to your buddy list Edit/Delete Message Reply w/Quote
Marcb
Senior Member
Has anyone ever noticed screws missing from the liner material? I had fog lights installed at the Honda Dealer when the van was new. I wonder if they lost some parts or something? There are 2 holes on each side that look like they should have a screw but none are installed.
__________________
-Marcb
2006 Odyssey EXL Slate Green/Gray
RES + NAV
2001 VW Jetta TDI Black/Black leather
1992 Toyota PU 4WD Pearl Red/Gray
1987 MB 300D Turbodiesel Ivory/Palo
1985 Toyota PU 2WD Ivory
1960 MB 190Db Classic Diesel Benz
Old Post 02-05-2008 07:37 AM
Marcb is offline Click Here to See the Profile for Marcb Click here to Send Marcb a Private Message Find more posts by Marcb Add Marcb to your buddy list Edit/Delete Message Reply w/Quote
mjody
quote:
Possibly push in clips? I don't see any screws on mine.
__________________
96 Ody
90 Miata
98 CRV
Old Post 02-05-2008 06:09 PM
Marcb
Senior Member
I looked up and found a schematic on the College Hills website. It looks like they are called fender "retainer" clips. 2 white plastic clips with screws. I guess they lost them when the lights were installed...?
__________________
-Marcb
RES + NAV
Old Post 02-07-2008 08:02 AM
Show Printable Version | Email this Page | Subscribe to this Thread
Forum Jump:
Rate This Thread:
Forum Rules:
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is OFF
vB code is ON
Smilies are ON
[IMG] code is ON
< Contact Us - OdyClub >
Powered by: vBulletin Version 2.3.11
Copyright ©2000 - 2002, Jelsoft Enterprises Limited.
