OdyClub Forums - General Discussion New Page 1
Home  User CP   Register   Calendar   Member   F A Q   Search
OdyClub Forums : Powered by vBulletin version 2.3.11 OdyClub Forums > Accessory Forums > DIY Modifications > DIY Clock Replacement (with pics!) Thread Rating: 11 votes, 4.91 average.
Pages (24): [1] 2 3 » ... Last »   Last Thread   Next Thread
Author
Thread Post New Thread    Post A Reply
VT FIJI Graphix
Junior Member
Talking DIY Clock Light Replacement (with pics!)
My parents had a silly debate on whether or not the clock had a backlight. I took it upon myself to do some research and as I suspected, there was indeed a backlight. I came across this thread and decided to fix the lamp. The instructions were very detailed and overall, the process was fairly simple. However, there was a lack of pictures and I noticed there was a demand for them. Hopefully, this tutorial will provide some help to the people who were afraid to do it themselves. Keep in mind, this was my first time removing a dashboard.
I’ll go step-by-step through the pictures, so you don’t have to juggle back and forth between this and the other thread.
TOOLS REQUIRED:
- 10mm or 1/4" socket wrench to disconnect battery
- phillips screw driver
- working gloves
- tiny flathead screwdriver to remove hazard button connector
- wrapped flathead screwdriver for prying. (not needed if you have small fingers)
1. Here’s the part you need to buy, Radio Shack part #272-1092. Despite Radio Shack’s rip-off prices, this was only $1.49 for two micro lamps.
2. Disconnect the battery. Personally, I don’t believe this step is necessary, but you can do it to be on the safe side.
3. Put on the emergency brake. With the engine off, shift down it into the lowest gear to give yourself some clearance.
Old Post 03-09-2005 07:00 AM
VT FIJI Graphix is offline Click Here to See the Profile for VT FIJI Graphix Click here to Send VT FIJI Graphix a Private Message Find more posts by VT FIJI Graphix Add VT FIJI Graphix to your buddy list Edit/Delete Message Reply w/Quote
VT FIJI Graphix
Junior Member
4. Remove the panels to the left and right of the steering column. WEAR GLOVES! I found it easiest to start from the side closest to the steering column and pull from there. If you notice in the picture, I also removed the cap that covers the hole where a button is supposed to go. Use that hole to pull, too.
right side removed
left side removed
5. After you remove the left and right panels, you need to remove a total of 8 screws.
4 behind the right panel
2 behind the left panel
2 above the gauge cluster
Old Post 03-09-2005 07:01 AM
VT FIJI Graphix
Junior Member
6. Once those screws are removed, the top panel can be pulled out. The part by the gauges is the hardest to remove. Just be careful with the plastic panels and work your way from the sides.
top panel removed
7. Behind the top panel, you’ll notice two wires that connect to the hazard light and clock. You can unplug the clock easily, but the hazard light requires a small screwdriver to release the lock.
8. I took the top panel inside to give myself some more work space. Here it is lying on my kitchen table.
front
back
Old Post 03-09-2005 07:02 AM
VT FIJI Graphix
Junior Member
9. Remove the plastic housing that covers the clock. The lamp is located on the top left of the circuit board. It removes with a simple twist.
10. And after ALL that work, you can finally replace the lamp. I wish I took the picture with a penny to show a size comparison. It’s a shame it requires all this work to get to a tiny lamp.
11. Replace your panels and screws and you’re all done!!
SIT BACK AND ENJOY YOUR CLOCK AT NIGHT
Old Post 03-09-2005 07:03 AM
arvinthsiva
Senior Member
Cool work! Great pictures. I'll pass on to my friend with 2nd Gen Odyssey.
__________________
2005 - Honda Odyssey EX (Desert Rock Metallic) with Billet Grille
1995 - Volkswagen Passat V6
Old Post 03-09-2005 07:18 AM
arvinthsiva is offline Click Here to See the Profile for arvinthsiva Click here to Send arvinthsiva a Private Message Find more posts by arvinthsiva Add arvinthsiva to your buddy list Edit/Delete Message Reply w/Quote
BrianB
Senior Member
Nice job documenting the fix. I was under the impression that getting to the clock was impossible. I love these $2 part fixes.
BrianB
Old Post 03-09-2005 11:43 AM
BrianB is offline Click Here to See the Profile for BrianB Click here to Send BrianB a Private Message Find more posts by BrianB Add BrianB to your buddy list Edit/Delete Message Reply w/Quote
New Dad New Van
Senior Member
Thumbs up Excellent post on the clock light
This is a great post on replacing the clock light, especially with pictures. Pictures make all the difference! I had the clock light replaced under warranty already and now I feel like I can handle this myself if it burns out again with these pics... Thanks.
__________________
2001 Odyssey LX - WARRANTY WORK: top rubber sliding door gaskets, rear brake drums, clock light, driver's seat belt and EGR TSB performed.
UNOFFICIAL 2001 ODYSSEY THREAD: www.odyclub.com/forums/showthread.p...4664#post384664
1994 Subaru Impreza L
Old Post 03-09-2005 02:24 PM
New Dad New Van is offline Click Here to See the Profile for New Dad New Van Click here to Send New Dad New Van a Private Message Find more posts by New Dad New Van Add New Dad New Van to your buddy list Edit/Delete Message Reply w/Quote
egads
Senior Member
Once You have done this once, (I've done it three times-two Odys) you will be able to remove the lamp without removing the entire upper trim. I don't even remove anything on the left side but the screws above the speedo. Once you know what the lamp looks like (thanks for the pictures!) reaching in to twist it out is easy. One skipped step here is removing and replaceing the lamps from radio shack from the little grey plastic holder. You need a teenager's eyesight to do it. The lamp, when purchased from a dealer's parts counter, has the lamp as a complete unit. Considering how often the burn out, two for $1.49 sure beats one for $4.50 from the dealer.
Old Post 03-09-2005 04:41 PM
egads is offline Click Here to See the Profile for egads Click here to Send egads a Private Message Find more posts by egads Add egads to your buddy list Edit/Delete Message Reply w/Quote
VT FIJI Graphix
Junior Member
quote:
haha. I thought that part was self explainitory. It's a lot smaller than I expected, so you do need really good eyesight. I'm only 20, so I still have my eyesight.
Old Post 03-09-2005 05:07 PM
napalm747
Member
Has anyone looked at installing and LED in place of the radio shack bulb? If so does anyone know what LED (ie at Radio Shack) and how to do it (solder instructions etc). Also are the other lights for other items in the dash the same radio shack bulb? Might as well replace as many as I can get to when I do it.
Old Post 03-10-2005 10:38 AM
napalm747 is offline Click Here to See the Profile for napalm747 Click here to Send napalm747 a Private Message Find more posts by napalm747 Add napalm747 to your buddy list Edit/Delete Message Reply w/Quote
chan_man
Senior Member
Great job with the pictures.. should probably put this into the TECH section.. this question comes up often.
__________________
05 EX-L Midnight Blue Pearl
01 EX (traded in)
97 CRV
Old Post 03-10-2005 06:26 PM
chan_man is offline Click Here to See the Profile for chan_man Click here to Send chan_man a Private Message Find more posts by chan_man Add chan_man to your buddy list Edit/Delete Message Reply w/Quote
ody04
Senior Member
Great Job, I really love this work. Thanks for your great work and for pics.
__________________
'04 Odyssey EXL-RES (May'04 outside of Vin Range for Trany&Fuel Pump Recall)
Splash Guards
Cargo Try
Axxess Ipod Interface
2006 Toyota Prius
1996 Toyota Corolla - Totalled
1990 Nissan Maxima -- SOLD
Old Post 03-12-2005 07:51 AM
ody04 is offline Click Here to See the Profile for ody04 Click here to Send ody04 a Private Message Find more posts by ody04 Add ody04 to your buddy list Edit/Delete Message Reply w/Quote
Jerry O
CHAIRMAN OF THE BORED
This repair kinda reminds me of the time they had to remove the engine from my Chevy Citation in order to replace the rear crankshaft oil seal. If our light goes out, I think I will keep a flashlight in the console.
Jerry O.
__________________
UFCW Retired
UNION, YES!!!
(The labor movement, the folks who brought you the weekend)
2006 Ocean Mist Metallic EX-M(Mouse fur) + WeatherTech cargo mat, Mr. Grille, Dashhugger dashcover, ScanGauge, Magellan GPS, Acura MDX wheels, 245/50-18 Yokohama ADVAN S.4 tires and AirLifts. Also, a few "faux" items, such as "dual" exhaust outlets, smoked plexiglass foglight hole fillers, and miscellaneous homegrown ground effects items, topped off by an "R" next to the "Odyssey" on the rear liftgate.
2001 GG LX-R(revised), still in the family. Now at 85K miles.
1994 Dodge Caravan SWB w/3.0, still in the family w/ over 150K miles
Dyson DC17 vacuum cleaner (to maintain the "dash rug")
John Deere 14PZ mower (push-it-yourself)
Old Post 03-14-2005 01:05 AM
Jerry O is offline Click Here to See the Profile for Jerry O Click here to Send Jerry O a Private Message Find more posts by Jerry O Add Jerry O to your buddy list Edit/Delete Message Reply w/Quote
exitnine
Member
just be careful of the front panel, the bottom part, it break very easy, my dealer broke mind, they have to pay for the part, anyway, mind is still under warranty, and they seem they don't want to fix it at the first place, but my 03 ody is less the 20000 mile at that time, so they have to anyway, and i guess they have no idea what they are doing, anyway, if the light gone again, i am sure i will do it myself, thanks for the info.
__________________
07 - RAV4 4x4 - Classic Silver Metallic
03 - Odyssey EX - Starlight Silver
94 - Maxima SE - Super Black
92 - Galant - Classic Black
Old Post 03-15-2005 05:37 AM
exitnine is offline Click Here to See the Profile for exitnine Click here to Send exitnine a Private Message Visit exitnine's homepage! Find more posts by exitnine Add exitnine to your buddy list Edit/Delete Message Reply w/Quote
porschetr
Senior Member
My dealer replaced our 2001 two years ago.
But they had to do the same thing again next day because the machanic forgot to plug one of the connector back.
The signal wasn't working.
__________________
Old Post 03-15-2005 07:28 AM
porschetr is offline Click Here to See the Profile for porschetr Click here to Send porschetr a Private Message Find more posts by porschetr Add porschetr to your buddy list Edit/Delete Message Reply w/Quote
Show Printable Version | Email this Page | Subscribe to this Thread
Forum Jump:
Rate This Thread:
Forum Rules:
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is OFF
vB code is ON
Smilies are ON
[IMG] code is ON
< Contact Us - OdyClub >
Powered by: vBulletin Version 2.3.11
Copyright ©2000 - 2002, Jelsoft Enterprises Limited.
