OdyClub Forums - General Discussion New Page 1
Home  User CP   Register   Calendar   Member   F A Q   Search
OdyClub Forums : Powered by vBulletin version 2.3.11 OdyClub Forums > General Forums > Problems and Concerns > FYI Rust on 2002
  Last Thread   Next Thread
Author
Thread Post New Thread    Post A Reply
fathom
Junior Member
FYI Rust on 2002
Hi all,
My 2002 LX, with 97,000km (3000km short of rust warranty), was found to have rust on the passenger door.
The rust has perforated through (!), and fortunately will be repaired under warranty in the body shop. It is located just under the rubber joint closest to the door hinge on the INSIDE of the door.
The rust was also present ALL ALONG the top of the inside of the door under the rubber. Unfortunately since it has not gone through there I'm out of luck.
There were tiny paint chip from rust on the driver door also, again not perforated.
The manager said this is his 2 or 3rd van he saw with the same problem and said Honda Canada is blaming it on Ontario salt in the winter.
The van was sprayed twice with Krown Rustproofing.
Since the rust is on the inside of the door I don't think it matters how much you put your car through a wash over the winter.
Wow, and I thought the last rust bucket I had from Honda was my old 1981 Civic, which literally disintegrated over one winter in an indoor heated garage. Here we go again with Honda rust, this time the van was parked expressly either in the driveway or in the unheated garage when heavily snowing.
Hopefully, the van will last until my extended warranty runs out, and I'm not left with a rust bucket. Funny enough, my 1999 Saturn with no rust protection has less rust on it than the 2002 Honda.
To add insult to injury, they need the van for 3 days, and will not give a replacement vehicle.
Check the INSIDE of your doors.....you've been warned.
Old Post 09-30-2005 04:56 AM
fathom is offline Click Here to See the Profile for fathom Click here to Send fathom a Private Message Find more posts by fathom Add fathom to your buddy list Edit/Delete Message Reply w/Quote
x-sno snake
Senior Member
The Ody's must not be too susceptible to rust as "search" didn't turn up much on the 2nd Gen. Odys.
There is however, a trap in the rear suspension tube that you in the rust belt should take a look at. Pull one of the real wheels and you'll see a tube about 1 1/2 inches in diameter which runs the width of the vehicle. There probably is some sand in both ends near the tires, which will hold water and keep everything damp for extended periods of time every time exposed to water - especially in summer if you drive in rain. I shoved the hose with an old, straight brass nozzle in and pushed it almost thru and pulled it out without it hanging up. Be careful tho, the tube has openings near the center of the body judging from the water flow and could "hang up" on a projection like a pistol grip nozzle. Blew about four table spoons of sand out total. Since this is a structural member, rust damage would be very ungood a few years down the way and the 99's are now eight years old. If you have a fair amount of stuff in the tube, be sure to clean off the far side wheel so there are no out of balance issues from dirt on the inner rim. Maybe pull the far side wheel and be sure the disk brakes are not loaded with sand.
Not sure I want to try and seal the tube with covers or by blowing some "foam" in there or just clean them out a couple times a year. This Ody group is a clever lot so I'm going to wait and see what other solutions folks have come up with.
Old Post 05-29-2007 02:45 AM
x-sno snake is offline Click Here to See the Profile for x-sno snake Click here to Send x-sno snake a Private Message Find more posts by x-sno snake Add x-sno snake to your buddy list Edit/Delete Message Reply w/Quote
New Dad New Van
Senior Member
Pictures of the rust and the rear suspension tube would be great if possible.
Some threads on rust on the doors:
http://www.odyclub.com/forums/showt...;highlight=rust
Personally, I think an after-market rust-proofing product such as Crown or Rust Check is necessary for long-term owner's like myself.
I have seen rust on the rear wheel wells of an Odyssey only. This area is also an area of concern for rust. Run your finger along the inside top of the rear fender and you will find alot of crap. This crap gets wet and traps moisture. A jet of water in and around the well will clean it out. This is often forgotten when washing.
__________________
2001 Odyssey LX - WARRANTY WORK: top rubber sliding door gaskets, rear brake drums, clock light, driver's seat belt and EGR TSB performed.
UNOFFICIAL 2001 ODYSSEY THREAD: www.odyclub.com/forums/showthread.p...4664#post384664
1994 Subaru Impreza L
Old Post 05-29-2007 03:00 PM
New Dad New Van is offline Click Here to See the Profile for New Dad New Van Click here to Send New Dad New Van a Private Message Find more posts by New Dad New Van Add New Dad New Van to your buddy list Edit/Delete Message Reply w/Quote
x-sno snake
Senior Member
Ok, will take a photo and post it next week when we get home where all the good tools are.
Old Post 05-31-2007 05:39 AM
lastprodigy
Member
Not surprising, most cars from Ontario that we see here in western canada that are daily drivers or are 4+ yrs, or 80K Km or older definately start shwoing signs of rust, degree of it depends on the care taken as well I guess.
Old Post 05-31-2007 11:25 PM
lastprodigy is offline Click Here to See the Profile for lastprodigy Click here to Send lastprodigy a Private Message Find more posts by lastprodigy Add lastprodigy to your buddy list Edit/Delete Message Reply w/Quote
davedrivesody
Odyholic
Re: FYI Rust on 2002
quote:
Ontario now adds a chemical to the salt (truly forget its name) to create pre-wetted salt. This concoction is supposed to be more effective but is even more corrosive than salt alone. Go here to read more. Like New Dad said, anti-rust treatment is mandatory in this part of the country for anyone who plans to keep their van more than three years.
I know well the suspension tube that x-sno snake mentioned. Something to check next chance. Wonder if the rust treatment has gotten in there?
__________________
2002 Odyssey EX FG
Honda hood deflector, mud guards, Zymöl, Honda ATF cooler, Amsoil EaO20 oil filter, Amsoil synthetic 5W20, Krown rustproofing, block heater (gets cc...cold in Canada in winter!)
Old Post 05-31-2007 11:47 PM
davedrivesody is offline Click Here to See the Profile for davedrivesody Click here to Send davedrivesody a Private Message Find more posts by davedrivesody Add davedrivesody to your buddy list Edit/Delete Message Reply w/Quote
x-sno snake
Senior Member
Here is a photo of the drivers side rear brake disk and the suspension tube just behind it. You can see a light powder residue which was easily wiped out. This is an 03 Ody with 120,000 miles which has been to mn several times in winter and it shows. The tube appears like it may have been coated with something to enhance its life but keeping it clean will insure a long life.
This is a very easy maintenance item anytime one or both rear wheels are off the vehicle.
Attachment: ody rear disk 002 b.jpg
This has been downloaded 54 time(s).
Old Post 06-11-2007 01:02 AM
chadb
Junior Member
Re: Re: FYI Rust on 2002
quote:
I am from Northern Michigan Snow Belt country and I don't believe in the rust proofing process at all. Every vehicle that I have seen rust proofed starts rotting from the inside of the doors and rockers. Hmmm... could if be because of the holes introduced by the rust proof sprayers? I am absolutely convinced it is. Rust always starts bubbling the paint around the plugs they put in the holes. When drilling the holes they are creating a point of weakness for water infiltration and exposing the metal edge of the holes. Even if it is galvanized metal - it is only galvinized on the surfaces. If you drill holes, you have just compromised the integrity of the metal.
Just stay away from the money trap of rust proofing IMO.
Old Post 06-15-2007 09:07 PM
chadb is offline Click Here to See the Profile for chadb Click here to Send chadb a Private Message Find more posts by chadb Add chadb to your buddy list Edit/Delete Message Reply w/Quote
bbylon5
Senior Member
Smile Re: Re: Re: FYI Rust on 2002
That is true of waxy stuff like Ziebart etc..
But WDS (water displacing lubricant) types lile Krown and Rust check do work and I can speak from experience with my 13 year old voyager i traded in. All the door seams hatchback seams etc where 100% rust free and the body was the same adn this was 13 years worth of Ontario Canada winters where the roads turn white due to all the salt they put down.
As for the plugged hole being a source for water infiltration This is also not the case... More water gets in from the mouldings around thhe windows than anywhere else and since the plugs are locate on the inside of the door jam's they don't get exposed to water directly...
Now i will admit that I did see a minor about of bubbling around one or two of the plugs but this was not a rust through and this was a small cost to pay for no rust anywhere else..
I als ohad no problems with the lock mechanisms, windows tracks,motors or any of the electrical connections since the Krown/Rust check gives all of these a yearly coating of lubricant...
Check this writeup by the APA
http://www.apa.ca/template.asp?DocID=11
Annual rustproofing. The product is an excellent penetrant. It outperformed all similar products in ASTM durability tests {ASTMB-117}, and is used by the military and large commercial fleets. Krown recertifies technicians annually to maintain quality and provides excellent support from the head office. The application is thorough, with holes drilled using special bits to minimize damage. Most competitors cover about 10 areas on the vehicle; Krown does over 25. The cost is $100-$130 per year depending on the vehicle, and resprays are guaranteed against price increases for as long as you own your vehicle. APA members receive a $10 discount off the regular retail price of a Krown application. The Krown warranty covers seam or crevice corrosion, and is honoured across Canada.
Old Post 06-15-2007 11:51 PM
bbylon5 is offline Click Here to See the Profile for bbylon5 Click here to Send bbylon5 a Private Message Find more posts by bbylon5 Add bbylon5 to your buddy list Edit/Delete Message Reply w/Quote
Show Printable Version | Email this Page | Subscribe to this Thread
Forum Jump:
Forum Rules:
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is OFF
vB code is ON
Smilies are ON
[IMG] code is ON
< Contact Us - OdyClub >
Powered by: vBulletin Version 2.3.11
Copyright ©2000 - 2002, Jelsoft Enterprises Limited.
