OdyClub Forums - General Discussion New Page 1
Home  User CP   Register   Calendar   Member   F A Q   Search
OdyClub Forums : Powered by vBulletin version 2.3.11 OdyClub Forums > General Forums > 95 - 98 Odyssey > Major oil leak
  Last Thread   Next Thread
Author
Thread Post New Thread    Post A Reply
bobcca
Junior Member
Major oil leak
Tuesday evening we went to a restaurant about ten miles away. As we were entering the parking lot, I noticed the oil warning light starting to flicker. When I checked the dipstick, there was no oil reaching the bottom of the dipstick. Checking underneath, I found oil dripping from the left (alternator) end of the engine. I had the van towed to my favorite (non-dealer) mechanic. When I got home, I saw a puddle of oil in the driveway and a trail of oil down the street.
Next morning when I went to the mechanic's, he showed me where the seal had come loose on the balance shaft. Since I am close to 320,000 km (200,000 miles), we decided to change the timing belt, balance shaft belt and the water pump at the same time. As a preventive measure, we decided to replace the O-ring between the engine oil cooler and the engine block where the oil filter mounts.
When I picked up the parts at the Honda dealer, the parts guy suggested I install a seal retainer kit they use on older four cylinder Accords. It cost $5.34 CDN plus tax and the part number is 06923-P0A-306. Simple to install. Three hours of labour and we are back on the road.
If I had known about this seal retainer kit, this might have been avoided. No engine damage.... I attribute that to the use of Mobil 1 synthetic oil. However, since I recently started using Mobil 1 oil filters, I am wondering if that increased the pressure in the oil system and pushed the seal out of place.
Any ideas on this????????
Old Post 02-10-2006 10:33 PM
bobcca is offline Click Here to See the Profile for bobcca Click here to Send bobcca a Private Message Find more posts by bobcca Add bobcca to your buddy list Edit/Delete Message Reply w/Quote
hidperf
The boost gods call on me
Common problem. You're car should've have a recall performed on it. They used to tow them in 3 and 4 a day when I worked for Honda.
__________________
White 95 Odyssey LX7, Tein springs, 17x8 gunmetal 04 TL wheels and tires, 12" Fr. rotors, twin piston calipers, 35% tint, Pioneer head unit, Clarion coaxials, Infinity BassLink and loaded with Honda Accessories. Crushed
hidperf@gmail.com
Old Post 02-10-2006 11:06 PM
hidperf is offline Click Here to See the Profile for hidperf Click here to Send hidperf a Private Message Visit hidperf's homepage! Find more posts by hidperf Add hidperf to your buddy list Edit/Delete Message Reply w/Quote
Neil P
Senior Member
quote:
I have my mechanic in my driveway right now changing my valve gasket, distributor gasket, crankshaft seal, etc. It's a $350 job by his estimate. Are you saying that I should have just taken it to the dealer for a free fix? It's been losing about a quart every two months.
While he's there, I decided to have him also change the timing belt (86,000 miles). That's another $100, but it would have been $200 by itself. I'm about to buy a new Ody soon, probably this month. But, whoever buys this Ody will hopefully appreciate that I've been keeping on top of the maintenance.
Old Post 02-13-2006 06:28 PM
Neil P is offline Click Here to See the Profile for Neil P Click here to Send Neil P a Private Message Find more posts by Neil P Add Neil P to your buddy list Edit/Delete Message Reply w/Quote
hidperf
Yes, the balance shaft seal had a recall on it. You should check with your dealer so see if yours fell within the recall range. They used to reimburse customers who payed to have it done before the recall, I don't know if they'll pay now though.
__________________
hidperf@gmail.com
Old Post 02-14-2006 12:58 AM
Neil P
Senior Member
Well, it's only a $5 part, so there isn't any point in trying to track down a reimbursement.
Also, my mechanic told me that I already had one and he's replacing it. I had an oil leak about a year ago too. Maybe he added it then. I don't know.
Old Post 02-14-2006 01:32 AM
hidperf
was it a metal retainer that held the seal in place? That the part the dealer will install.
__________________
hidperf@gmail.com
Old Post 02-14-2006 01:39 AM
Neil P
Senior Member
I told him the name of the part and said it was some kind of retainer Honda installs as part of a recall. He seemed to know what I was talking about.
Old Post 02-14-2006 01:48 AM
leecea
Member
I've been trying to find details of this recall because I've taken mine into the dealer for an oil leak that appears to be coming from there and had no luck with them doing anything.
Anyone have a link or ref number I can use to find it?
EDIT: Search is a wonderful thing, but you never know where it will take you! I just realized I'm in the wrong forum for a 2000 Ody Bye...
Old Post 03-16-2006 03:21 PM
leecea is offline Click Here to See the Profile for leecea Click here to Send leecea a Private Message Find more posts by leecea Add leecea to your buddy list Edit/Delete Message Reply w/Quote
Show Printable Version | Email this Page | Subscribe to this Thread
Forum Jump:
Forum Rules:
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is OFF
vB code is ON
Smilies are ON
[IMG] code is ON
< Contact Us - OdyClub >
Powered by: vBulletin Version 2.3.11
Copyright ©2000 - 2002, Jelsoft Enterprises Limited.
