OdyClub Forums - General Discussion New Page 1
Home  User CP   Register   Calendar   Member   F A Q   Search
OdyClub Forums : Powered by vBulletin version 2.3.11 OdyClub Forums > General Forums > 95 - 98 Odyssey > ..big puddle of oil.
Pages (3): [1] 2 3 »   Last Thread   Next Thread
Author
Thread Post New Thread    Post A Reply
MindEddy
Senior Member
Unhappy ..big puddle of oil.
It's 20f degrees outside (cold for us) and the Ody is sporting a true "horror story" scene in the driveway. From the front door, we can see it sitting at the top of the driveway (sun rise behind it) with a large oblung puddle of fresh oil beneath it.
The oil is barely hitting the dipstick, but it is registering. The van ('96 Ody) has not had the hood open in about 3 weeks. We've had a winter storm come through in the last two days, but nothing else unusual to mention.
Last night the oil light began blinking as my wife made the last few blocks home.
When it gets up around 30 outside, I plan to go investigate. Any ideas where to start???
(the oil, from quick examination, seems to be coming from "mid - to left (when facing) side", so more over on the tranny side, rather than the timing cover side. The puddle is fairly large in the driveway, so obviously it didn't need pressure to leak out in the end.)
Thanks,
ME
New Info........there is a fairly solid trail going all the way down the drive, then forming a small (fist size) puddle before heading down the street. This tells me (considering two trips yesterday) that the van was actually leaking badly as she left for first outing, of two, yesterday afternoon. Odd that the oil light only blinked upon return last night AND the puddle in drive is so large. (yes, she does notice lights very well)
__________________
MindEddy
96 Odyssey LX 4cyl - 125k
98 Accord EX 4cyl VTEC - 195k
96 Accord 4cyl (slipping transmission) - 205k **SOLD**
Old Post 12-03-2006 04:11 PM
MindEddy is offline Click Here to See the Profile for MindEddy Click here to Send MindEddy a Private Message Find more posts by MindEddy Add MindEddy to your buddy list Edit/Delete Message Reply w/Quote
mjody
Is it foggy in here???
The balance shaft oil seal has popped out. It was an issue with the F22 and F23 motors. Now you need to tow it to a repair shop.
Looking at a new seal and a retainer that holds it in. Also, get your tech to do the timing and balance shaft belts as they are now soaked in oil and ruined.
There was a recall for installing the retainer, yours sounds like it was never done.
Old Post 12-03-2006 04:35 PM
mjody is offline Click Here to See the Profile for mjody Click here to Send mjody a Private Message Find more posts by mjody Add mjody to your buddy list Edit/Delete Message Reply w/Quote
MindEddy
Senior Member
....in addition, it actually was NOT registering on the dipstick. I added 1 quart and moved the Ody forward 5 feet, then added two more quarts to register on the stick. Also, the 'new' puddle has begun and is more to the right of center than I first thought.
I assume this seal you speak of is the one that is part of the good "timing belt kits" and the one that comes with the new 'retainer'. I was looking at purchasing a TB kit and remember text saying "...aftermarket retainer for...." most likely what you are referring to.
The dealer is 45 miles away and our only local Honda specialist shop got consumed by a 'big dealer' 6 months ago.
Ahh......this too shall pass.
ME
Started it for about 30 seconds, now the puddle is growing like the 'Blob'. 99k miles. Guess the decision on doing the timing belt is made for me.
__________________
MindEddy
Old Post 12-03-2006 04:45 PM
hipermax_d
(>.<)> HAI!! paMAX!!
this just happened to me last week. and i had my dealer fix it.
the dripping of the oil is from a broken O ring in the oil filter adapter. it drips furiously whneever the engine is running
this thread tells you all about it.
http://www.odyclub.com/forums/showt...assive+oil+leak
__________________
Old Post 12-03-2006 06:14 PM
hipermax_d is offline Click Here to See the Profile for hipermax_d Click here to Send hipermax_d a Private Message Find more posts by hipermax_d Add hipermax_d to your buddy list Edit/Delete Message Reply w/Quote
MindEddy
Senior Member
.......don't tease me.
Do you realize how wonderful it would be if that was all it was?? Now you make me want to crawl under there tonight.
ME
__________________
MindEddy
Old Post 12-03-2006 06:29 PM
MindEddy
Senior Member
...hipermax.....you might be my hero for the day. At least I'll thank you for a good night's sleep.
I'm freezing (25 here) but I couldn't resist crawling under the van real quick. The oil filter 'area' is soaked with oil and the area around the timing belt it perfectly dry. I'm going to let the oil pan (one solid chunk of ice) thaw out and get back under there tomorrow, but right now it looks like it IS the oil filter holder. I'll now for sure after I crank it, but unless there is something else above that area, it must be that filter.
ME
__________________
MindEddy
Old Post 12-03-2006 06:48 PM
GreenGen1
Junior Member
long time looker, first time as member
mine just failed on thursday night.
big puddle too.
o-ring had split. bought o-ring at dealer 91316-PT6-003 for $2.58.
took oil filter off, used a 30 mm socket to remove the through bolt that holds cooler to block.
new o-ring is slightly larger than the groove on the cooler.
you need to be sure that the o-ring stays in the groove or it will be immediately damaged.
i chilled mine in the freezer to shrink the new o-ring and then stuck it on with some wheel bearing grease to hold it in place.
About 1 hour, the leak was stopped and the van had a new oil change.
good luck fixing yours.
Old Post 12-03-2006 08:00 PM
GreenGen1 is offline Click Here to See the Profile for GreenGen1 Click here to Send GreenGen1 a Private Message Find more posts by GreenGen1 Add GreenGen1 to your buddy list Edit/Delete Message Reply w/Quote
MindEddy
Senior Member
...GreenGen,
Thanks for posting. Tis' the season for Oil filter holder seals?
Is yours also a '96 Ody?
ME
__________________
MindEddy
Old Post 12-03-2006 09:54 PM
stussycole
Senior Member
Mine did that a couple of winters ago. Here is my write-up.
O-ring Repair
Old Post 12-03-2006 11:14 PM
stussycole is offline Click Here to See the Profile for stussycole Click here to Send stussycole a Private Message Find more posts by stussycole Add stussycole to your buddy list Edit/Delete Message Reply w/Quote
MindEddy
Senior Member
cole - this is why I love this forum!
Great pictures. Exactly what I was needing. I planning to order a manual from Helms tomorrow. Biting the bullet on the $62. ($87 with shipping and tax) Also, I WILL need to snag a 31mm.
Thanks a million.
ME
__________________
MindEddy
Old Post 12-04-2006 12:34 AM
GreenGen1
Junior Member
Mind Eddy
mine is a 96 also. I used a 30mm socket and it fit fine.
Stussy Cole
great photos, that is exactly the same way my o-ring failed. I started thinking too about what some of the other o-rings might look like, and how many are easy to replace like this one and how many are difficult to replace.
I do think that with the experience and knowledge on this board that the Gen 1's can continue for a long time.
Old Post 12-04-2006 03:16 AM
stussycole
Senior Member
I can double check the size socket that I used. I seem to remember getting the 31mm because the 30mm was out of stock. Anyway, it worked, just took my time and made sure I was as seated on the bolt as I could be.
Old Post 12-04-2006 04:07 PM
tech126
Senior Member
Good write up guys!!! As a tech for a local Honda dealer, I've never seen that oil seal go, but now I plan to change my seal at the next oil change for preventive purposes..
By the way, how much miles did your vans have before the seal went out??? Just curious..I have 101,765 so far..
thanks in advance!!
Old Post 12-04-2006 04:43 PM
tech126 is offline Click Here to See the Profile for tech126 Click here to Send tech126 a Private Message Visit tech126's homepage! Find more posts by tech126 Add tech126 to your buddy list Edit/Delete Message Reply w/Quote
GreenGen1
Junior Member
mine is a 96, failed at 103,851. This was our first big cold front of the winter (temps in the upper 20's) and the o ring may not have been able to adapt to the cold.
the o ring was very hard, not flexible at all and split just like the photo in stussycole's writeup.
the parts man at the honda dealer said he was selling a lot of these o rings lately. seems that a lot of 2.2 engines have this cooler between the filter and the block.
tech 126 if you know of other common failures from your work at a honda dealer please let us know.
Old Post 12-04-2006 04:50 PM
Robert
Senior Member
quote:
Mine had about 164K when I noticed and replaced it. My oil sending unit was also leaking.
__________________
http://www.gbcpalestine.org/youth.mht
'95 Taffeta White 7 seater (Now 6 seater) LX Ody
Mods:
Hubcaps from 03 Accord LX, Fog Lights, OEM front map lights, OEM Roof Rack, Lumar metalized tint, Honda upgraded speakers/tweeters, Passenger armrest, Valiant keyless entry, Adjustable Second Row Bench is gone, now beige bucket seats! 216K miles and going strong!
My Ody: http://www.odyclub.com/forums/attachment.php?s=&postid=98576
2004 Toyota Sienna LE 110K miles (The new family hauler)
1993 Sentra SE-R current and slow coming project.
Robert is offline Click Here to See the Profile for Robert Click here to Send Robert a Private Message Find more posts by Robert Add Robert to your buddy list Edit/Delete Message Reply w/Quote
Show Printable Version | Email this Page | Subscribe to this Thread
Forum Jump:
Forum Rules:
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is OFF
vB code is ON
Smilies are ON
[IMG] code is ON
< Contact Us - OdyClub >
Powered by: vBulletin Version 2.3.11
Copyright ©2000 - 2002, Jelsoft Enterprises Limited.
