OdyClub Forums - General Discussion New Page 1
Home  User CP   Register   Calendar   Member   F A Q   Search
OdyClub Forums : Powered by vBulletin version 2.3.11 OdyClub Forums > General Forums > 05+ Odyssey > 2007 Odyssey Technical Service Bulletins (TSB)
  Last Thread   Next Thread
Author
Thread Post New Thread    Post A Reply
New Dad New Van
Senior Member
TSB 08-045 Chirp From the Timing Belt Area
Applies To: 2005–2007 Accord V6 – ALL
2005–2007 Odyssey – ALL
2005–2007 Pilot – ALL
2005 –2007 Ridgeline – ALL
http://www.in.honda.com/Rjanisis/pubs/SB/A08-045.PDF
TSB 07-005 Power Steering Pump Whines, Buzzes, or Hums
Applies To: 2005–07 Odyssey – ALL
2008 Odyssey – From VIN 5FNRL38..8B000001 thru 5FNRL38..8B075356
2008 Odyssey – From VIN 5FNRL38..8B400001 thru 5FNRL38..8B419525
http://www.in.honda.com/Rjanisis/pubs/SB/A07-005.PDF
TSB 07-023 Driver’s Power Seat Doesn’t Move Forward or Backward
Applies To: 2005–06 Odyssey (except LX)
2007 Odyssey (except LX) – From VIN 5FNRL3...7B000001 thru 5FNRL3...7B026590
2007 Odyssey (except LX) – From VIN 5FNRL3...7B400001 thru 5FNRL3...7B420216
2006 Ridgeline – From VIN 2HJYK1...6H500001 thru 2HJYK1...6H519353
http://www.in.honda.com/Rjanisis/pubs/SB/A07-023.PDF
TSB 07-028 Pinging, Rattling, or Squealing During Light Acceleration
Applies To: 2005–06 Odyssey: ALL
2007 Odyssey:
thru 5FNRL3...7B007592
thru 5FNRL3...7B405900
http://www.in.honda.com/Rjanisis/pubs/SB/A07-028.PDF
TSB 07-051 A/C Cooling Is Poor; Condenser and Radiator Fans
Do Not Switch to High Speed
Applies To: 2007 Odyssey – From VIN 5FNRL3...7B000001 thru 5FNRL3...7B111734
2007 Odyssey – From VIN 5FNRL3...7B400001 thru 5FNRL3...7B456153
http://www.in.honda.com/Rjanisis/pubs/SB/A07-051.PDF
07-063 Engagement Delay After Shifting From P or R
Applies To: 2007 Odyssey:
EX-L, Touring (With VCM Engine) -
From VIN 5FNRL38..7B000001 thru
5FNRL38..7B121203
From VIN 5FNRL38..7B400001 thru
5FNRL38..7B458691
LX, EX (With VTEC Engine) -
5FNRL38..7B121721
5FNRL38..7B458780
http://www.in.honda.com/Rjanisis/pubs/SB/A07-063.PDF
TSB 07-065 Steering Column Pops or Clunks While Turning or Accelerating
Applies To: 2007 Odyssey – ALL
http://www.in.honda.com/Rjanisis/pubs/SB/A07-065.PDF
TSB 07-067 Rear Entertainment System DVD Does Not Load, Play, or Eject
2006–07 Pilot – ALL
http://www.in.honda.com/Rjanisis/pubs/SB/A07-067.PDF
TSB 07-080 Driver’s Position Memory System Does Not Work
Applies To: 2007 Odyssey – From VIN 5FNRL388.7B114384 thru 5FNRL388.7B123130
http://www.in.honda.com/Rjanisis/pubs/SB/A07-080.PDF
TSB 07-084 RES Headphones Don’t Work in DVD Mode
Applies To: 2005–07 Odyssey – All Models With Rear Entertainment System
http://www.in.honda.com/Rjanisis/pubs/SB/A07-084.PDF
TSB 06-058 2007 Odyssey: PDI and New Model Information
http://www.in.honda.com/Rjanisis/pubs/SB/A06-058.PDF
TSB 06-068 Vehicle Pulling or Drifting
Applies To: ALL
http://www.in.honda.com/Rjanisis/pubs/SB/A06-068.PDF
TSB 06-072 TPMS Sensor Tool Usage
Applies To: 2007–08 Odyssey – ALL except Touring
http://www.in.honda.com/Rjanisis/pubs/SB/A06-072.PDF
TSB 06-089 2007 Honda Paint Codes, Exterior and Interior Color Code Locations
Applies To: 2007 Models – ALL
http://www.in.honda.com/Rjanisis/pubs/SB/A06-089.PDF
TSB 05-012 Moonroof Glass Weatherstrip Is Damaged
Applies To: 2005–07 Odyssey: ALL
http://www.in.honda.com/Rjanisis/pubs/SB/A05-012.PDF
TSB 05-032 Navigation System DVD Information and Inspection
Applies To: 2000–08 Odyssey
http://www.in.honda.com/Rjanisis/pubs/SB/A05-032.PDF
TSB 08-071 Engine Pings During Moderate to Heavy Acceleration
2008 OdysseyLX, EX:
Production Line 1 –
FromVIN 5FNRL38x.8B000001
thru 5FNRL38x.8B037706
Production Line 2 –
FromVIN 5FNRL38x.8B400001
thru 5FNRL38x.8B410388
NOTE: x equals 2 or 4
EX-L, Touring:
Production Line 1 –
thru 5FNRL38x.8B037448
Production Line 2 –
thru 5FNRL38x.8B409144
NOTE: x equals 6, 7, 8, or 9
http://www.in.honda.com/Rjanisis/pubs/SB/A08-071.PDF
TSB #08-084 Time on Display Changes Randomly
Applies To: 2005–09 Odyssey with Navigation – ALL
http://www.in.honda.com/Rjanisis/pubs/SB/A08-084.PDF
TSB #08-088 Service Manual Update: Poor AM or FM Reception
Applies To: ALL 2004–09 Models
http://www.in.honda.com/Rjanisis/pubs/SB/A08-088.PDF
TSB 07-045 Brake Pedal Is Low and Feels Soft
Vehicles Affected: 2007–08 Odyssey – ALL
http://www.in.honda.com/Rjanisis/pubs/SB/A07-045.PDF
TSB #08-078 Electrical Problems and B-CAN DTCs After Exposure to Water/Water Leaks
Applies To: 2005-2009 Odysseys
http://www.in.honda.com/Rjanisis/pubs/SB/A08-078.PDF
TSB # 09-042 Damaged Camshaft Position Sensor (CMP) Causes the MIL to Come On With DTC P0344
http://www.in.honda.com/Rjanisis/pubs/SB/A09-042.PDF
TSB # 09-047 MIL Comes On With DTC P0962, P0963, P0966, P0967, P0970, or P0971
http://www.in.honda.com/Rjanisis/pubs/SB/A09-047.PDF
Power Sliding Door Stops at Half-Latch Position, Won’t Close
Currently Applies To: ’05–09 Odyssey
http://www.in.honda.com/Rjanisis/pubs/SN/A09060t.pdf
Rear Wheels Howl or Moan When Braking
http://www.in.honda.com/Rjanisis/pubs/SN/A09060o.pdf
TSB 09-053 Product Update: Lock-Up Clutch Judders Between 20–45 MPH
Applies To:
2009 Odyssey LX, EX:
Production Line 1 –
FromVIN 5FNRL3...9B000351
thru 5FNRL3...9B056551
Production Line 2 –
FromVIN 5FNRL3...9B400201
thru 5FNRL3...9B410343
EX-L, Touring:
Production Line 1 –
FromVIN 5FNRL3...9B000201
thru 5FNRL3...9B050869
Production Line 2 –
FromVIN 5FNRL3...9B400321
thru 5FNRL3...9B405632
http://www.in.honda.com/Rjanisis/pubs/SB/A09-053.PDF
TSB 09-054 Power Doors Continually Lock While Driving
Applies To: 2007 Odyssey – ALL Touring models
2008–09 Odyssey – ALL
http://www.in.honda.com/Rjanisis/pubs/SB/A09-054.PDF
__________________
2001 Odyssey LX - WARRANTY WORK: top rubber sliding door gaskets, rear brake drums, clock light, driver's seat belt and EGR TSB performed.
UNOFFICIAL 2001 ODYSSEY THREAD: www.odyclub.com/forums/showthread.p...4664#post384664
1994 Subaru Impreza L
Old Post 08-19-2008 03:25 PM
New Dad New Van is offline Click Here to See the Profile for New Dad New Van Click here to Send New Dad New Van a Private Message Find more posts by New Dad New Van Add New Dad New Van to your buddy list Edit/Delete Message Reply w/Quote
jackrabbit000
Senior Member
Any TSB's for '06?
Old Post 08-19-2008 08:09 PM
jackrabbit000 is offline Click Here to See the Profile for jackrabbit000 Click here to Send jackrabbit000 a Private Message Find more posts by jackrabbit000 Add jackrabbit000 to your buddy list Edit/Delete Message Reply w/Quote
dvpatel
Senior Member
quote:
Originally posted by jackrabbit000
Any TSB's for '06?
Patience man. He is working on it.
__________________
The value of a forum such as this one is not in that one can post a question and receive an answer, but in that the question has most likely been asked before, and the answer is available to him that will but only use the search function.
2007 EX-L R&N, Slate Green with Olive (couldn't muster up the courage to trade my 1999 baby) ... Ours
2001 Emerald Green Pearl Accord V6-LX (Replaced the POS Taurus) ... Hers ...
..... Tranny replaced 6/4/08 @ 67,977 miles.
..... Tranny strarted slipping only 8,414 miles after the replacemnt.
..... 2nd tranny replacement 9/21/2009 @ 76,659 miles.
1999 Sterling Mist Nissan Maxima SE with Bose and 6 Disc CD Changer in the trunk ... All Mine
1993 Maroon Ford Taurus GL (Was a POS after the clock turned 60K Miles) ... Traded for the Accord
alexmish1's Customer Acceptance Checklist
alexmish1's Rattle Kill
Old Post 08-19-2008 08:35 PM
dvpatel is offline Click Here to See the Profile for dvpatel Click here to Send dvpatel a Private Message Find more posts by dvpatel Add dvpatel to your buddy list Edit/Delete Message Reply w/Quote
New Dad New Van
Senior Member
Gettin' there on the 2006s. Not looking forward to the 2005s though (about 35 TSBs)...
__________________
Old Post 08-20-2008 03:16 PM
esteeze
Member
Thanks for taking time to write these up... will be good reference to bookmark for later.
__________________
- 07 Ody EX (wife's car; kid hauler; had since 12/2007)
- 06.5 VW Jetta TDI (my commuter; had since 4/2007)
- 04 Ody EX (lease ended 1/2008)
- 03 Honda CR-V EX AWD (sold 6/2007)
- 97 Ford Explorer Eddie Bauer (traded for CR-V 9/2003)
- 93 Honda Civic LX (sold 9/2003 after 10 years of ownership)
Old Post 08-20-2008 04:10 PM
esteeze is offline Click Here to See the Profile for esteeze Click here to Send esteeze a Private Message Find more posts by esteeze Add esteeze to your buddy list Edit/Delete Message Reply w/Quote
New Dad New Van
Senior Member
2 new TSBs added to original post:
__________________
Old Post 07-02-2009 04:21 PM
New Dad New Van
Senior Member
Applies To:
Production Line 1 –
Production Line 2 –
EX-L, Touring:
Production Line 1 –
Production Line 2 –
__________________
Old Post 07-14-2009 02:47 PM
New Dad New Van
Senior Member
__________________
Old Post 07-21-2009 03:29 PM
Show Printable Version | Email this Page | Subscribe to this Thread
Forum Jump:
Rate This Thread:
Forum Rules:
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is OFF
vB code is ON
Smilies are ON
[IMG] code is ON
< Contact Us - OdyClub >
Powered by: vBulletin Version 2.3.11
Copyright ©2000 - 2002, Jelsoft Enterprises Limited.
