I know, I know, this has been discussed many times in the past but I have to solve this issue. For the 4th time this year a door was not closed enough and the interior lights drained the battery overnight. What a hassle and by the way a very poor design from Honda.
I have read other threads regarding this and some talked about a Priortity Start device. Has anybody order and installed this device? It looks to me to be a pretty good answer to a terrible Honda design.
I thought the same thing - ordered two of them, one for the Odyssey and one for my daughter's Toyota. Installed the one on the Toyota first, that's when I discovered the terminal provided on their device (which has to connect to the positive post on the battery) was a "one size fits all" which didn't fit the Toyota (their terminal was too big; I couldn't tighten it securely on the battery post). I called the company; they said they were aware that their product's terminal wouldn't fit some foreign cars and suggested I use shims. I don't believe in shimming battery terminals so I sent both of the devices back for a refund. Couldn't tell you if it would fit the Odyssey or not, but based on my one conversation with this company I decided not to give them my money.
If you ran down your battery 4 times in the last year, I assume that irreversible damage has been done to the battery. Did you pursue any batteries with rundown protection?
I heard there was some battery which shut off when it got drained down to a certain level so that you can start the car.
I'm puzzled. The Ody interior lights shut off automatically after a few minutes if a door is left open. Am I not understanding the circumstance in which Certek's lights remained on?
Re: Re: Bad Design = Dead Battery = Priority Start?
Not in my case. The door was left open and the lights never shut off. Maybe there is a timer but it does not work in mine. I have read all the other problems on this board regarding interior lights and assumed that my van was functioning the way it was designed. I do not have the manual handy to look it up.
I believe our our 2002 EX that if the interior light switch is in the "ON" position, that the lights will stay on regardless. If they are in the center position, they go out after three minutes, and if it is on the "OFF" position, they are always off.
In the my LX, the way it was explained to me and I will verify with my manual tonight, if the interior light switch is in the "ON" position, that the lights will stay on regardless. If they are in the center position they stay on regardless, and if it is on the "OFF" position, they are always off.
I went and looked at Honda's website and there was no mention of a difference between the 2003 LX and EX in regards to interior lights. They did still mention the auto-off headlights diference between the two models.
There seems to be some mis-information out there. I talked to Honda today and my dealer and they both stated that in fact there is no auto off feature for interior lights on either the LX or EX. Although in talking with both of them I did not get the feeling they truly understood what they were saying. I also think we here at the ODYCLUB have know more about the van than they do. So to me the jury is still out. Any other opionions out there?
It's not opinion, it's fact. I own an 02 EX, and the interior lights turn off after 3 minutes of the door being open--as long as the light switch is in the center position. Up, the lights stay on regardless; down, they stay off regardless. Center position, they go off after 3 minutes if the doors are still open. On the LX, they don't automatically go off; they stay on as long as the doors are open. That's one of the differences between LX and EX. There are many other differences; that's how the marketing people design the details to get you to spend the extra money.
The mechanism that turns off the interior lights is COMPLETELY different than that which turns off the headlights. Don't see the word "lights" and start lumping all lights together and making assumptions like that.
You are 100% correct. Got a hold of the manual and there is in fact a timer in the EX that is not in the LX. You have to read the manual to get this info. I do not recall seeing this in any product literature. I only recall the difference in the auto-headlight feature described in the product literature. Thus, if you have an LX like myself, then you are SOL. Back to my original question, anybody have the Priority Start unit installed?
Sorry to confuse you here. What I was ment by my post is that in the ON position the lights turn on and say on regardless of the door swich position. In the center position, the door swich determines if the lights are on. When the swtch is in the center position, if the door is open the lights are on and will stay on until the doors are closed or you push the switch to the off position. This is true for the LX model only since there is no off timer on the LX model. I hoped this helped. I read it myself and it is clear as mud.
I also agree that this feature seems to be pretty petty to exclude but that is just what they did. I can understand alloy wheels, better stereo and even auto-off headlights, but to exclude this feature seems a little rediculous.
Here's another Honda boner. With the dash switch in the center position, and the doors closed, the lights should turn off. However, if someone has turned on one of the interior lights AT the light itself (reading light), then it will not auto shutoff ever. If left on and undetected for a long period of time, like overnight, then you're gonna need a jump start in the mornin'.
... if someone has turned on one of the interior lights AT the light itself (reading light), then it will not auto shutoff ever. If left on and undetected for a long period of time, like overnight, then you're gonna need a jump start in the mornin'.
Not in my experience. I've had no trouble starting the engine after finding that *ONE* of the reading lights has been left on all night. This has happened many times (sigh). In contrast, when I leave that damn console switch in the up position all night, then I can never start the car in the morning.
I notice that the NAVI has battery protection built-in. If the NAVI is on when the engine is off, after about 10 minutes a message pops up explaining that it's powering down to save the battery. All they had to do was move the detection circuit outside the NAVI and put the lights on it. Kind of silly that they have a battery protection circuit in the car but it's not properly designed to adequately protect the battery.
I did the dirty deed a couple of days ago. I was cleaning the inside of my windows and entered the van from the left-hand slider. I finished that side and slid over to the right and cleaned those windows. I got out through the right-hand door and went in for the night. Yep, the left door was not all the way latched and I left all the candles burning (as John Force would say). Of course, when I came out in the morning, all the interior lights were barely glowing and by the time I decided what I was going to do, they were going on and off.
I have an automatic charger, so I put it on a slow charge and brought the battery up slowly and hope it will not be too damaged for the experience. One problem now is the the battery condition "eye" does not seem to work anymore. I had the one in my Dodge battery quit working, fairly early, and the battery lasted years afterward. We'll see.
I have decided to just switch the interior light off completely, since we hardly every go anywhere at night. We can always re-arm them, should we need them.
I have never had one bulb take a battery down overnight, but, I did have a trunk light stick on while using the car for short trips only, never getting out of town, for days at a time. It was a new car and in a matter of a few days, I found my battery dead. I discontinued, i.e. unplugged the light (very poor switching device, which could never be trusted), and never had another dead battery. The problem with the Odyssey is that it has seven "candles" and they get the job done overnight, with ease.
Well I am tired of having to check the lights all the time and I am worried that my wife and kids will be stranded in the future. Thus, I ordered my Priority Start on Friday. Will be in on Monday and when I get a chance I will install it. Hope all goes well and I'll let all know how it worked out.
Jerry, mine also no longer has the green eye. As I recall, this means that the battery needs some more distilled water added, but this thing appears not to have filler ports.
I would think about the water issue, except that it was bright green until I discharged the battery. My theory is that the floating part of the built-in hydrometer (I assume that is what we have) has probably gotten into a bind and cannot come up high enough to give us the "green light". I have a power pack which I carry with me all the time, so I'm gonna keep on driving it and see how it goes. Maybe I'll hit a bump and knock the little "bobber" loose, Hee! Hee!
Just a quick update here, installed the unit yesterday and tested it - worked as manufacture claims. Battery voltage went to 11.86 volts and it disconnected the battery and had plenty of juice left to start the van. Not a lot of places to install it but I was able to get it in right behind the positive battery terminal. All went well and I think this is a real good device for anybody that has an LX model.
Related Threads
Honda Odyssey Forum
1.1M posts
411.7K members
Since 2000
Odyclub community is the #1 forum to discuss all things Honda Odyssey: minivans, safety, service maintenance, mods, and more.
