GriffithLea
Junior Member
Posts: 26 |
sevenmiles,
I don't think there's anything new. If you don't have the software update, you should get it, otherwise Honda might try to claim you were negligent if/when it comes time to replace your torque converter.
At just shy of 36,000 miles, I called up the Honda dealer and said I wanted to bring it in to be checked before the warranty goes out. Just to remind you, in my case the TC was replaced before the software update came out, so my new TC had a few thousand miles with the "bad" software.
Anyway, they told me that actually the powertrain has until 60,000 miles before the warranty runs out, so I did not take it in, since the problem comes and goes after the TC replacement. I'd already been made to look like a hypochondriac once after the TC replacement.
So, I'll wait another 20,000 miles. By then, it should be back to the constant upshifting feeling if the new TC was damaged during its time with the old software.
Here is what I think Honda won't admit - they are using the TC lockup clutch to mitigate the weird feeling when the VCM kicks in and out, and as a result the TC lockup clutch is getting overworked and begins to slip. Probably the new software is just being a bit less aggressive in its VCM compensation efforts.
__________________
2007 EX-L Slate Green w/o RES w/o NAV
Weathertech Bug Deflector
Weathertech Cargo Liner (behind 3rd seat)
Honda Fog Lights Add-on
Mr. Grille
Polk Audio db651s speakers (all 4 locations)
