OdyClub Forums - General Discussion New Page 1
Home  User CP   Register   Calendar   Member   F A Q   Search
OdyClub Forums : Powered by vBulletin version 2.3.11 OdyClub Forums > General Forums > Problems and Concerns > odyssey surge - big issue - anybody post if you had this problem
Pages (2): [1] 2 »   Last Thread   Next Thread
Author
Thread Post New Thread    Post A Reply
make_shift
Member
I was at a stop light though and it wanted to get going, so i put it in neutral and it almost stuck at red-line (about 6krpm) and stayed there, put it in park, turned off engine and on restart, no issue again...very strange, found something very close logged as a complaint on nhtsa.org - geez, sometimes it sucks that the drivers have to be matlock on these kinds of issues.
2005 ex-l
Old Post 12-29-2005 04:54 AM
make_shift is offline Click Here to See the Profile for make_shift Click here to Send make_shift a Private Message Find more posts by make_shift Add make_shift to your buddy list Edit/Delete Message Reply w/Quote
Atchie
I hope I can, I hope....
Re: odyssey surge - big issue - anybody post if you had this problem
quote:
2005 ex-l
Not sure if what I experienced tonight was the same type of thing:
After getting on the freeway and getting up to speed (speed limit is 70, but I usually won't go faster than 65 in this particular spot), I let off the accelerator a bit and the engine?trans was still racing and the rpm's were still higher than they should be indicating that it wasn't shifting into 5th gear like it usually would by this point. This stretch of freeway is one I frequent so I am familiar as to how the van should be working.
I have been having issues with what I now fear is the transmission, but it has typically been at slower speeds...
I'm just about at the end of my detective thread with this one
__________________
05 EX-L/ Nav/Res Sagebrush Pearl/Ivory
Old Post 12-29-2005 08:03 AM
Atchie is offline Click Here to See the Profile for Atchie Click here to Send Atchie a Private Message Find more posts by Atchie Add Atchie to your buddy list Edit/Delete Message Reply w/Quote
mobial
Junior Member
Hmmm. Just tonight we were sitting in the driveway at a firends with the car in park and I got out and noticed the engine was revving up and down, up and down. Never had this behavior before - 2002 Ody -- when we drove back home it was acting "odd" but my wife was driving so I can't explain it any better.
Old Post 12-29-2005 08:29 AM
mobial is offline Click Here to See the Profile for mobial Click here to Send mobial a Private Message Find more posts by mobial Add mobial to your buddy list Edit/Delete Message Reply w/Quote
make_shift
Member
we were at a stop light, on Christmas day no less, and the van wanted to go through the light, luckily I reacted quickly, but the brake pedal was really working, you could feel it fight the van from going forward, then put it in neutral, rpm's flew up to 6000 and stayed there, with a noise from the engine that an engine shouldn't make - can't even really explain the noise, put it in park, turned it off and waited a couple of sec's then re-start and here we are, no codes, nothing, just a really bad taste in my mouth.
Old Post 12-29-2005 02:36 PM
egads
Senior Member
Mobial, the behavior being described here concerns 05+ Odys with drive by wire accelerators. Your problem sounds like a known issue with a broken or loose power steering control switch. Could also be an idle air control valve. Take it to the dealer. If it is the power steering switch, you should not have to pay.
Old Post 12-29-2005 06:31 PM
egads is offline Click Here to See the Profile for egads Click here to Send egads a Private Message Find more posts by egads Add egads to your buddy list Edit/Delete Message Reply w/Quote
mobial
Junior Member
thanks egads, I took it over there - based on another thread I thought maybe something to do with the Intake Air Control Valve - and when I got there, there was some kind of EGR recall or something -
Old Post 12-29-2005 09:14 PM
MRichmondJ
Junior Member
I posted in an earlier topic a few weeks ago about a similar issue that my mother experienced in her '06 Ody EXL -- vehicle surged forward without her applying the accelerator. The dealer ran the diagnostic and said nothing was wrong, but I have seen at least three other separate descriptions of the same problem on other discussion boards -- very serious problem if it can't be fixed or Honda won't acknowledge.
Old Post 01-01-2006 06:25 PM
MRichmondJ is offline Click Here to See the Profile for MRichmondJ Click here to Send MRichmondJ a Private Message Find more posts by MRichmondJ Add MRichmondJ to your buddy list Edit/Delete Message Reply w/Quote
Atchie
I have noticed while at extended stops (in line at the bank, fastfood, etc) that the engine fan cycles on and off constantly. And when it comes on, the van surges forward. It'll run for about 10 seconds, turn off for 7 seconds and just keeps this cycle up. This happens regardless of the a/c being on. Is this normal?
__________________
Old Post 01-01-2006 07:36 PM
make_shift
Member
quote:
can you get me info on what other boards you saw this on or pm or email me your vin (I will send you myn if you like - we are on the brink of getting rid of this van because I don't want my family to be a statistic for an issue - but want to make sure I have as much proof as I can before I make that step, it wouldn't really be wise to just walk away without letting them try to make it right) -- let me know if you will help, you can email me by using my cp. thanks, and hopefully we can help light the torch to getting this fixed dammit.
because, no, in my opinion, none of the things on this thread seem normal, none of them.
Old Post 01-02-2006 01:16 AM
make_shift
Member
check your email.
Old Post 01-02-2006 04:53 PM
imhip2
Canadian Member
Very similiar problem!
Almost the same day!
Same part of Canada!
Same modle 2005 EX-L!
Boxing day I was at Terminal 3 going up in the parking garage doing about 20km/h and went to stop the van just kept acceleratating. Had the brakes on full and the ABS was just pumping until we came to a stop about 1 van length past the stop sign. Put the van in Park and revs went up to 6K and I shut off the key. Started the van up and then no problem. Luckily there was no one ahead of us.
I did report the incident to Honda as well because I also did not want to be a statistic. They also found no code had registered.
Van had 34,800 Km on it when it occured an it has not occured again although I feel the van now lags on and off like the transmission is dieing ( had it checked - no problem) or the power steering is dieing (had it checked - no problem)
Perhaps there is a problem with the drive by wire in these things!
Taking the beast in for service an A12 service (42,000 Km) and will mention there are others who had the same problems!
Makeshift - Let me know if you have had any luck resolving your problem and which GTA dealer you are dealing with.
__________________
Tim
2008 Buick Enclave New Jan 10, 2009
2005 Odyssey EX-L (Silver) Feb 5, 2005 New - 135,000 Km Traded Jan 10, 09
2007 Mazda 3 GT Sport (Phantom Blue) New-045,000km
1999 Mustang Convertible 5 spd (Triple Blk) New - 101,000 KM
1985 Accord LX 5 spd (Dk Grey) New - 205,000 KM - replaced with 1991 Accord
1991 Accord EX-R 5 spd (Seattle Silver) New - 313,000 KM - replaced with 2000 Civic
2000 Ody LX (Fern) New - 152,000 KM (and only one tranny replaced!)- replaced with 2005 Ody
2000 Civic SE 5 spd (Plum) New - 205,000 KM - replaced with 2007 Mazda 3
Old Post 03-17-2006 04:12 AM
imhip2 is offline Click Here to See the Profile for imhip2 Click here to Send imhip2 a Private Message Find more posts by imhip2 Add imhip2 to your buddy list Edit/Delete Message Reply w/Quote
make_shift
Member
I took it into 2 dealerships, in brantford and stratford, not gta, but dealer did a couple of recalls on fuel throttle sensor relay, i had problem with power steering pump, they replaced it, no problems since the surge incident, I keep my camera in van now in case it happens again to get more info for them. they really believe me, just can't find the problem...maybe a camera shot will help, hopefully not after I am wrapped around a tree.
Old Post 03-17-2006 04:11 PM
imhip2
Canadian Member
Thanks - Good to know. I will have them check those items when it goes in next week.
Good Luck keeping out of trouble and Happy St Patricks Day
__________________
Tim
Old Post 03-17-2006 04:20 PM
jerdesab
Junior Member
I had civic 01 before and experiencing loss of power. There were days once you step on the gas pedal you could feel the power and most of the days it was very sluggish and does not pick up the power. I could hear big vrooommm but slow response. In other words...power were not consistent everyday. I brought to dealer all said " can not duplicate the problem" I gave up and just lived with it for 2 years. power ok ...power not ok.
I decided to exchanged it to Honda Ody 2003 . I was happy for a year but second year and up to now 2006 with 38k, I experienced the same inconsistent power. I was trying to tell myself that it might be probably on my mind and imagining things..but no...I guess, I am being haunted by Honda's inconsistent power day after day...I could feel, hear and sense that engine's power is changing.
Shouldn't it be that every time of the day, every day of the week and every week of the month, POWER should be consisten???
Any comments is highly appreciated.
Old Post 11-13-2006 11:22 PM
jerdesab is offline Click Here to See the Profile for jerdesab Click here to Send jerdesab a Private Message Find more posts by jerdesab Add jerdesab to your buddy list Edit/Delete Message Reply w/Quote
imhip2
Canadian Member
I am still surging along...... getting worse day by day.
Steering pump replaced at end of March. Brakes done in June
I think mine is related to the torque converter or transmission, VCM, waiting to see what goes first. Still have 37,000 KM of warranty to have it break.
I asked the dealer about a TSB re the transmission that I found here but it only applies to the USA..... Guess we can't have those problems in Canada
__________________
Tim
Old Post 11-14-2006 02:11 AM
Show Printable Version | Email this Page | Subscribe to this Thread
Forum Jump:
Forum Rules:
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is OFF
vB code is ON
Smilies are ON
[IMG] code is ON
< Contact Us - OdyClub >
Powered by: vBulletin Version 2.3.11
Copyright ©2000 - 2002, Jelsoft Enterprises Limited.
