newdaddy
Senior Member
Posts: 254 |
I'm not positive about the 97 model, but one reservoir should serve both front and rear. Check the rear nozzle to see if it's clogged. You can probably use a straight pin or very thin wire to unclogg the nozzle. Then check the tubing that connects to the nozzle. When the hatch is open, you should be able to see a small diameter tubing (either clear or black) that feeds the nozzle. Check to make sure it's connected properly and not kinked. If it's clear, check to see if there is fluid inside. If no fluid, you will have to follow it upstream towards the hood to find out where the fluid is "stopping". Good luck.
__________________
'02 RRP EX-L
Mud guards, ScotchGuard carpet, 35% smoke tint front side windows, 7" LCD rear entertainment, add on reverse lights, Cargo tray, 5 brake light mod., Weathertech side deflectors
'93 Prelude SI VTEC- prefamily days...
'82 Accord LX hatchback- 1st car
