1 - 5 of 5 Posts
GoLowDrew
Why does this happen and how can I fix it? The left side is used every day. Flip down to block the sun. And flip back up. Over the years, it's not flipping back up as it should. The right side is hardly use and it's perfect.
2014 Odyssey. My 2010 Accord have the same problem. I should not accept it as "old" as a reason because this never happened on my past Hondas (or other brand of cars). Just these two current Hondas.
No problem with mine but did replace one on daughters Civic a couple years ago. If the internal clip breaks there is little to nothing that can be done to "repair" the visor. I just replaced the thing and the newer one has held up well.
Since your vehicle is relatively new, can you take it to the dealer and ask if can be replaced free of cost?
My wife's Civic (2010) had the visor clip broken after regular usage and we took it to Honda in 2013. They replaced it free of cost saying it's a known issue and hence they're replacing it free of cost.
1 - 5 of 5 Posts
