Odsquad is dropped and it feels and looks good
BBS CI-R out of your three choices
I love my H&R springs. perfect for a daily used van.That drop is perfect for the van. Can you take few more pictures for me...tryna convince myself to get the H&R springs for my new van lol.
That depends on the rims and tires you use (width, height, etc)I haul a lot of merchandise in the back (seats folded down) The van sags quite a bit. Will the H&R springs cause any issues like rubbing?
Stock TE rims, nothing aftermarket.That depends on the rims and tires you use (width, height, etc)
You can also use helper bags in the rear springs to stop the squat.
Then you'll be fine. The wheels will just go in to the wheel well. I would still look in to helper bags though.Stock TE rims, nothing aftermarket.
Which air lift kit did you get? I plan on getting H&R springs and the air lift kit.I find my Air Lift 1000 bags squeak just a little bit (I keep them around 25psi at all times). I actually found them to squeak MUCH more frequently when I had the stock springs. Putting the H&R springs on actually really reduced the squeaking. Even then, it's not an annoying squeak, just a little reminder I have them every time I pull in or out of my driveway. But they are very worth it.
No issues with my H&R springs after 5k-6k miles. Having problems with the airlift bags in the rear, going to rip it out soon. Lot's of squeaking, don't mind it but rear passengers don't like it.No issue so far - Don't put to many km's on her but so far love the look even with stock wheels
