UPDATE in AUG 2022 - following extensive debugging and no repairs at all, this problem eventually fixed itself and has been fine for over a year now. Still possibly useful info in here for others, but that was the "answer" in my situation. Still on the original alternator at 136k miles, having replaced the alternator pulley (OAD) at around 90k.
Also to be clear for people finding this with a common alternator failure ... this is not that. In a true alternator failure, you will have electrical problems where the alternator does not generate current and maintain voltage as it should, and you would probably get a warning light and message. In my case, I got the light, sometimes the message, but NEVER had any electrical problems I could measure.
2011 Odyssey LX, about 110k miles, no problems at all until ...
the red battery light (that is supposed to indicate a problem with charging) has been coming on intermittently starting a week or so ago, along with the CHANGE bATT message. When this first happened, I checked voltages = all good, the battery is less than 2 years old = good, I pulled the 2P connector on the battery negative terminal to reset the battery management, all connections tight. So I just told my wife (who drives this car) to pay attention and keep me posted.
Now that she's on a trip a few hundred miles away, the one-time problem has become intermittent and is now happening more frequently. Following instructions over the phone with me just now, she confirmed 12.2V battery voltage this morning before driving, then the red light came on while driving, then at the end of her brief trip, without shutting the engine off, she went and confirmed 13.9+V at the battery, while idling. This done using a voltmeter on the battery posts.
So it seems to me that the alternator is good and the battery is good.
Any ideas on what could possibly cause the red charging indicator light to come on like this?
