I have a 2007 EX-L with 224K miles. We rarely had problems with the power sliding doors, and recently when the battery died (after my not using it for a couple weeks when going out of town), both sliding doors quit working. I've spent many hours researching and trying all suggestions in this forum, other forums, and YouTube, but haven't found anything that works.
I tried every possible combination of all the fuse tricks (like resetting #7 on the driver's side as well as the others on the passenger side and under the hood), and I tried all combinations of having the doors open or closed, then having various ignition settings, etc. NOTHING worked. I also tried disconnecting & reconnecting the negative battery cable and that didn't help.
I suspect it's getting power to the PSD because when I manually close either door, I can see & hear the door motor automatically finish fully closing the door. The doors manually roll & close fine without any feeling of resistance or obstruction. There is no display on the instrument panel about a problem with the PSD. When I press the PSD switches (when it's in the "On" position), nothing happens - no motor sounds or beeps or anything like it's even trying to work.
What other options am I missing? Since this started when the battery died, I suspect it has to be a reset/homing issue and not a roller or motor issue, but I am a loss for what else to try. Please HELP! Thanks!!
