At 196,000 mi a squeaking noise started occurring at low speeds over gradual bumps. It sounds like it's coming from the front left side. Anyone out there with suggestions?
After spraying hot hot soapy water all over the wheel well and the white salt road spray covered suspension components. This squeak is gone.You could spend hours doing this. Spray some WD-40 on a suspected component where it moves or touches something else. Do one component at a time and drive in between to see if you've isolated the source.
In my experience, low speed soft squeaking has come from aged rubber components.
