1 - 16 of 16 Posts
DN12O-ody
With my 2012 EXL, it misfires pretty consistently once the car is fully warmed up and the engine is revved above 2500 rpm or so. Won’t rev above 3000. Multiple P030X codes. 125k miles. Runs great when cold.
The valves have been adjusted, as well as all coils and plugs replaced. This was by a local indy honda specialist. Took it to the dealer, they said compression was low and that it needed a new engine, but I had difficulty getting any more info from them beyond that.
Its Probably not worth an engine swap or ring job, but is there anything else I might check before giving up the car to the scrap heap? 🙁
thank you.
Codes were 0305, 0306, and 0300. Yes, I’ve read up on the VCM disable but was wondering if it was too little too late at this point.
Then read the megathread fully. There is no such thing as too late, and it is addressed in the megathread. Though 5 and 6 are non-VCM cylinders.
those misfires are not vcm related, although the bad compression on certain cylinders may be.
Did they give a compression test report for all cylinders?
What brand and what was the source for each of those? (since it is a Honda specialist, hopefully they used the right parts - but worth checking)
Reactions: MrRangerZr1
Discussion starter · #9 ·
Thank you all for the ideas.
Timing Belt was replaced 25k/2 yrs ago. Coils were Honda, not sure about plugs, I will check.
Dealer wasn’t forthcoming on compression numbers, I got the sense they were just trying to get me out of the shop as quickly as possible. ;-)
Just because the timing belt was replaced doesn't mean the timing can't be off.
Fuel pump issues are almost unheard of on Hondas.
Discussion starter · #12 · (Edited)
Understood. Can a garage check the timing without physically accessing the timing belt (just from diagnostics), or do you have to get in there. To check it?
thanks again.
edit: interesting too that when cold, you can rev it to redline and it’s perfectly smooth. If the timing was off, would it misbehave all the time?
thanks again.
You can remove the upper timing covers and rotate the engine to see if the timing marks line up.
thanks again.
Can check with the inspect holes on the covers.
With the timing off by say a tooth, at first It will seem like it runs like a charm, will even go to redline. But it will start misfiring very soon after. I dealt with a van like this before. Hopefully you don't have any internal damage.
Discussion starter · #16 ·
Timing looked fine. So I decided to roll the dice and installed a new fuel pump. Ranger’s YouTube video on that process was very helpful. And surprise surprise… it seems to have fixed the problem. Driven it for a couple of hours since in many conditions, and no more misfire.
1 - 16 of 16 Posts
