The lights work. Just the lens that's faded. Can I just pop off the lens without removing bumpers, etc?
You can not remove the front “lens” of the headlight. It is an integrated unit. Replacing the headlight requires removing the bumper cover, which is easy to do.The lights work. Just the lens that's faded. Can I just pop off the lens without removing bumpers, etc?
OR you can do the red***k method like I do before big trips.The lights work. Just the lens that's faded. Can I just pop off the lens without removing bumpers, etc?
It's theoretically possible since it started as a separate part, although the assembly would have to be removed from the van. The problem would be restoring the perfect factory seal. Realistically, removing the lens is not possible.Can I just pop off the lens without removing bumpers, etc?
Thanks. Just ordered new assemblies.It's theoretically possible since it started as a separate part, although the assembly would have to be removed from the van. The problem would be restoring the perfect factory seal. Realistically, removing the lens is not possible.
Anyway, the lens is not available anywhere, so removing it would be a dead end.
Your options are to replace the assembly or to refinish the lens.
I refinished mine using the Maguire's kit. It looked good, but didn't last long. So I replaced the assemblies. I regularly polish the lenses with the UV protectant left over from the kit.
