Hello everyone. This is my first post so please let me know if I made any mistakes. I couldn't find any posts related to this so here it goes.
The short of it is: Has anybody used head gasket sealer with any reasonable success? Or know of another alternative to head gasket / engine replacement?
The whole story is:
I have a 2010 EX-L with about 145k miles on it. I bought it about 2 years ago and preemptively put a VCMuzzler on after reading so many warnings on this forum. Thanks for that heads up =) Unfortunately now I have a problem that I originally attributed to VCM but after a week of research I now believe it is probably a head gasket issue.
My original symptoms were a CEL with P0301 and P0302 codes. I checked the plugs and the 3 from the rear bank were considerably more fouled than the front bank. So I replaced the spark plugs with OEM NGK plugs and rotated the coil packs to see if the issue reappeared or moved to a different cylinder. I then reset the CEL to see if it would reappear. After about a week the codes reappeared so it's definitely not the spark plugs or coils.
I did a piston soak with Berryman's B12 and some ATF and made sure to turn the engine for a total of about a minute with ignition and fuel disabled and spark plug holes covered with rags to get rid of all fluids to avoid locking the cylinders up. I cleaned the old spark plugs and put them back in. Re-enabled fuel & spark and started the engine. I also topped off all fluids including coolant since I was already working on the car.
Almost immediately I got smoke coming out which I'm lead to be believe is normal after a piston soak. Let it idle for a few minutes and shut off. Next day I decide to take it for a drive. Initially, no smoke. After some time I start to see a lot of white smoke and the CEL comes on and starts flashing. I drive home and rechecked the plugs.
Now my symptoms are CEL with P0301 and P0302 codes, losing coolant over time and now what looks like white smoke out the tail pipe. I haven't had a chance to do a compression test or a leak down test but I checked the spark plugs and the ones on the rear bank seem to be somewhat fouled.I'm currently 90% sure that the head gasket is the issue.
My local mechanic quoted me $3800 to replace the engine since they don't believe in head gasket replacement. My local Honda quoted me $3200 for head gasket replacement. That's a lot of money IMHO to pour into a 12 year old minivan. So I'm looking for alternatives. Has anybody had any luck with a head gasket sealer? Even if I have to flush the cooling system and remove the thermostat, I think spending $70 on a "permanent" head gasket sealer is better than spending over $3000 even if the "permanent" solution only works for 2 years. I hear the risks are clogging the radiator or other circuits in the cooling system but at this point I'm already looking at a car with a dead engine so how much worse could it be? What are your thoughts?
The whole story is:
