Van has been showing intermittent "Check Fuel Cap" message for few days. Checked the O-Ring on fuel cap and seems fine. Foxwell scanner showed codes for large leak and fine leak. Anyway i cleared it and drove again. Now the engine light is blinking 5 times and scanner showed EVAP system not ready.
Scanned it again and it showed very large leak detected. Progressed from large leak to very large leak. Seems the pressure build up by the Leak detection pump is leaking out fast. Gas cap seems to be fine. So with the help of my son, i started checking the issue. With a smoke machine, it is lot easier, but since i don't have a smoke machine, i did it with the hand held vacuum pump i have.
1) Removed the EVAP valve and the middle plastic pipe close to the canister.
2) I closed the pipe with my finger while my son was using the vacuum pump on rubber host after EVAP valve. Success. No leak. So the system is leak free from after EVAP valve to canister
3) Now checked the EVAP valve it self. Electronically, it is working. But when i tried to use the vacuum on each side, from one side, it is not holding vacuum and leaking pretty fast. Indicating that the valve is leaking internally.
4) Was about to buy the new EVAP valve, then thought of cleaning it. Used brake cleaner on each side, electronically activated the valve and blew air through it. Both ways. Did it 2 times.
5) Now it passed my vacuum lest. Holding vacuum from both sides.
Since the Foxwell scanner i have can't initiate the EVAP test forcefully, i have to wait the ECU to run and see if it works or not. If fails again, i will replace the valve.
Just wants to update the forum with my observations.
