I am wondering which to fix first (actuator or multiplexer) if my PASSENGER SIDE door lock stopped working In my 2001 EX? My driver side door lock and back hatch work. My passenger slider door lock also doesn’t work. Thank you!
Does your front passenger door lock work OK with the key in the outside slot?
Does your front passenger door lock and unlock with the manual button on the passenger door by the window?
Does that door lock with any of the electric buttons on the fob or on the drivers door?
Are your sliding doors electric or manual?
Answering these may help others help you.
Also use the Search feature in this forum for possible answers.
Also, try google for some answers.
Buffalo4
Discussion Starter #4
@Buffalo4
  1. Yes, the key works on the passenger side
  2. No, the passenger side manual lock inside does not work
  3. No, it does not respond to any buttons on the fob
  4. I have electric sliding doors
I have searched and read several posts on this subject. It seems like they all start with the driver’s side lock not functioning. My driver’s side works perfectly.
Thank you very much!
Melissa8
If the manual key works but the manual knob does not, problem could be with the linkage inside the door. Pull the door panel off and investigate.
