1 - 10 of 10 Posts
Been looking for a thread/sticky on how to remove factory radio. Cant seem to find one. I removed large trim piece that surronds radio but nor sure how it comes out. I tired to slip removal tabs along side of radion but that does not seem to work.
If the 2 screws need to come out how do you fit screwdriver in there? (Its at 90 degree angle)
thanks
Manual says 6 screws total after removing center panel? It does look tight in there to get at those screws.
Someone must have done this before?
There are two bolts on either side of the radio that need to be removed. Should be quite visible as they are right next to it. You can use either an 8mm or phillips to remove them. Both the pocket and the radio come out together.
The four bolts that need to be removed are just to the left and right sides of the radio and should be quite visible. Here is a quick pic of the right side ones on mine.
Just remove them and pull the radio out.
Discussion Starter · #9 ·
I dont see those brackets on my OEM radio. Did you install these brackets when you installed your after makets radio?
Nope, those are the factory brackets. I bolted the aftermarket radio to them to keep the pocket. Even the parts websites show the same brackets. If you can take a pic of your dash with the panel off and post it, it might help to figure out what is different on yours.
1 - 10 of 10 Posts
