A/T gear position indicator does not indicate shift lever positions.
Transmission range switch defective or out of adjustment
Shift cable broken or out of adjustment
Joint in shift cable and transmission or body worn
Check the D indicator, and check for loose
connectors. Inspect the transmission range
switch. If the transmission range switch is
faulty, replace it. If the transmission range
switch is out of adjustment, adjust it and the
shift cable.
Check for a loose shift cable at the shift lever
and the transmission control shaft.
