I went to get in my 2002 EX the other day and suddenly it just popped back like I had reclined it fully. Now it wont stay up period. I just searched the forum topics and couldnt seem to find a match. Any insights on this particular problem would be greatly appreciated!
Thanks!
Do you (or anyone) know about what the cost is of getting this fixed? The links to the honda parts place designated (which refer to a part #20 and #21 seem to no longer exist).
Thanks again,
Jeff
Discussion Starter #4
Fixed!
Took into dealer today and they fixed it for under $100. Turns out a couple of bolts had broken and a weld. They were able to fix it by simply replacing the bolts. This said I am a very happy camper! The other problem folks have described sounds pretty expensive for something like this.
2011 Odyssey LX, 120k miles
One of the links above refers to a TSB 01-066. I've searched the site for it and googled and cannot find a free copy. Can someone point one to me?
My '99 has what seems like a similar problem, but not as bad as the OP. I took it apart a year or so ago to investigate. There are a few different documented problems with the seat. For example, Honda TSB 02-059 refers to additional shims to reduce the side-to-side wobble. But this does not seem to be a problem for us.
We've got an up-down wobble and if leaning back while adjusting up, it will skip.
From taking it apart and investigating ...
The up-down wobble is due to the several rivets in the seat frame base ("ADJUSTER ASSY. L. SLIDE") (81660-S0X-A21) and recline adjuster assembly (81630-S0X-A21) having worn enough to allow motion. Does not appear to be easily repairable - these components would probably need to be replaced ($648 for seat frame base, $215 for recline adjuster assembly)
The skipping of the recline adjuster can be avoided by leaning forward while adjusting the recline. A motor twists a cable which probably drives a worm gear which turns a pinion gear which moves the rack. All of this is part of the recline adjuster assembly. Since it is assembled by rivets (big ones), this is probably non-serviceable. Potential safety issue at some point if this problem worsens to allow the seat back to recline by itself (e.g., during acceleration); not clear if this could happen, or if the worm gear would prevent this - i.e., it will slip when being driven, but will not back-slip.
