When the door is closed it isn't flush with the side of the van...plus, occasionally, the sliding door light indicator will flicker...I've read where this is an indication of the door needing to be adjusted. Thx.
Clean the door contacts for the light. As for the door adjustment you need to check all the rollers to see if any are missing or worn. There are several adjustments that are covered in several of the threads on the site.
