My 03 clock and transmission indicator lights flicker when idling. Alternator new about 2 months ago. (Remanufactured)
ANy ideas. THanks
Your remanufactured alternator (aftermarket?) is the problem. If not Denso, it will not work or last properly.
Many of us have made the same mistake. Never, ever use an aftermarket alternator on the Ody.
Sent from my SM-N910V using Tapatalk
All I did was replace the brushes on my original alternator after 220,000 miles. If you still have your old alternator, check the brushes and replace them. Mine where still good for a few thousand more miles, but changed them out as a precaution as my indicator lights would dim every so often during power surges.
