Ok so I changed the tensioner pulley and needed a new bolt on alternator did all that drove it home just fine shut it off came out 2 days later tried to start it did but then died right away but it was cold and I couldn't hit pedal . Tried starting again seemed to fire descent but wouldn't quite start thought ok bat so I jumped it and now when I crank is the motor turns over with a bad noise and doesn't fire at all checked to see if my valves were still moving when cranked and they are seems to get worse everytime I try it I suppose I'm going to have to check timing belt any other suggestions would be greatly appreciated thanks
