I am hearing a slight whine from my automatic transmission ('05 LX). It only happens when the transmission is in 4th gear and I am accelerating. It is a fairly high-pitched whine. It almost sounds like a high-pitched vacuum leak but since it only happens in 4th gear I believe that rules out a vacuum leak. I am guessing it is a bushing or bearing in the transmission. I have no codes and the transmission shifts and runs fine else wise. Anybody have similar noises?
I purchased the vehicle with 93,000 and it is now approaching 97,000. I hadn't noticed it until a couple of weeks ago. It has gotten colder here and I am thinking the cold might be what made it show up. I am the second owner and have no warranty on this vehicle so if it fails I am guessing Honda isn't going to do anything for me.
I am planning to do a full flush and fill. I found good information in a Honda Technical Bulletin that I will use. (I am posting it under the title, Automatic Transmission Flush and Fill). Any other thoughts or suggestions are appreciated.
