A/C stopped working some weeks ago, wife put up with it until now. A visible check shows that the compressor isn't spinning. I checked the pressure and got ~30 psi on the low side and about the same on the high side if I recall (didn't commit high side press. to memory). I just checked the clutch relay and the coil resistance was 145 ohms. I checked that there was voltage on one of the relay socket pins. Put a jumper across that open contact and nothing happened; I heard to clutch pulling in. Got under the car but didn't jack it up and looked/felt on the top side of the compressor. Found the clutch wire and see that it goes to a plug/recept. near the fan. I doubt that there is a problem with the connector but I'll check it. If it's not the connector I suspect the clutch is bad. I can turn the compressor by hand with not too much torque; the resistance is consistent and it turns 'kinda' smooth. Are there any other tests that can be done? I've read many posts and see that some owners have replaced the clutch and some replaced bearings too. However if it's truly failed I guess I'll just replace the compressor complete. I'm on a tight budget so I can't afford to pay >$1000 for the dealer or indy to fix it.
