I've read through many of the sliding door problems on these forums and have yet to find anybody with the same problem I'm having...
Hoping somebody with more mechanical experience than me may have an idea of what might be the cause of my problem.
Symptoms - when using either the key FOB or the button on the driver left side dashboard, the door will not open. It will sound like it's trying to open, then go "click click click click click" and do basically nothing.
The door can be opened manually from the inside/outside handles. When I say manually, I mean that when you pull the handle, it will make the same clicking noise described above but as long as you hold the handle and kind of "help" the door open it will "catch", you can remove your hand from the handle and it will open normally. Same thing for closing. Pull the handle and as long as you continue to hold/pull the handle it will click for a bit until it catches and then close automatically all the way.
Asked the dealer about it last time I was there and all he could tell me was that it was hundreds of dollars to even diagnose because of the labor involved in opening up the door.
Hoping somebody can help?
Thanks.
Thanks.
