1 - 2 of 2 Posts
My 07 Ody is developing cupping on both f&r tires and causing rumble noise at both local and freeway speed. Does anyone experiencing this and how do you fix it?
BTW, I just completed with balancing and alignment done few weeks ago but still makes noise. The tech at this shop thinks it's the shock but not sure if this is the case here.
Thanks.
Once the problem is found and fixed the only thing that will get rid of the cupping is replace the tires. Have you been rotating the tires? Have the front suspension checked out by a good shop as anything could cause it and rotating tires will propogate one wheel problem to all tires. If not and all tires are cupping you could just have a bad set of tires. Anytime tires are rotated they should be closely inspected for defects.
1 - 2 of 2 Posts
