Problem: My passenger side slider will close perfectly, but it won't open with the dash or key fob buttons. It will open fine, when you use the inside or outside door handle.
Yes, I've search and read endless threads on this issue.
I've tried cleaning and greasing the tracks, adjusting the door to make it fit better and operate smoother. I've tried the fuse trick combined with disconnecting the battery for good measure. Nothing works.
What I have determined, is that the door latches are not disengaging the front and rear strikers automatically. I figured this out, by removing them both, and then operating the door remotely. It works perfectly when both strikers are removed, but if either the front or rear striker are installed, the latches do not disengage automatically, so the winch tries to pull the door open (which won't work with the latches engaged), and then gives me 3 error beeps.
When I use the door handle (inside or out), it mechanically releases the latches, so the door works fine this way.
Any ideas what would cause the latches to not disengage?
