1 - 9 of 9 Posts
doing some maintenance on the old beast and noticed adrop of oil on bottom rear bolt. pot a wrench on it and gave it a little wiggle to se if it was loose, tightened maybe 1/8 of a turn and now its dripping. ac still works fine.
this one is around 8 years old
Automotive tire Motor vehicle Tire Bumper Vehicle
2006 Honda Odyssey (EX)
its 100% oil from compressor, i watched it bubble out of a hole in the center of the bolt. i did the heads, and oil pump last year after i burned a valve. all gaskets are holding, not a drop of oil on the motor.
2010 EX-L
Could it be refrigerant leaking from the compressor?
There should be oil in the refrigerant so it may appear to be oil when in fact in might be “oily” refrigerant.
Discussion Starter · #8 ·
yes it is oil and refrigerant leaking refrigerant going into the air and oil is dripping. but its not from a crack or seam its a bolt with a hole in the center almost like a petcock or drain. but i touched it and it started leaking more
1 - 9 of 9 Posts
