1 - 7 of 7 Posts
My right side marker light stopped working but left works perfectly fine so I ordered LED for both sides replaced the left (works) and the right doesn’t turn on?
Even tried the original oem light from the left to the right side. No luck. Nothing looks burnt
Try reversing the LED bulb installation. LED bulbs have to go in a particular way. I realize you said you tried the original OEM bulb, but perhaps that was burned out.
I’ve removed the working one from the left side and tried it on the nonworking side. (Right) No light.
I’ve also try reversing as well.
I’ll try again and make sure I didn’t miss anything
If the bulb doesn't lock in place, sounds like a damaged socket. I had that happen with one of my taillights.
Reactions: zxzADRIANzxz
1 - 7 of 7 Posts
