Hi,
My Odyssey now has now driven 58100 miles and 20% Oil life left. So I assume the car will be due for the 60000 miles service.
Can somebody of you tell me what usually needs to be done at 60k miles?
Regards,
Niels
Sent from my Autoguide iPhone app
My 2007 just done with B13 code at 61,000 km and 5% oil life left.
General inspection plus engine oil & transmission fluid replacement.
Found worn front bushings, otherwise all good.
Hi,
61000km or 61000 miles? :)
I've done transmission oil change outside the regular maintenance about 6 month ago.
So 60k is no spectacular and expensive service?
No, its just routine... most warranties run out at 60k miles. Check thewarranty items and such before you hit the magic cutoff numbers... oh I did Franny fluid flush and fill in addition to normal oil change.
