I would definitely shop around for the timing belt job. I have had $500-900 quotes and get the water pump done at the same time(serpentine belt should be included so ask). Do NOT let them charge you for more than 1/2hr. labor and the price of the pump when getting timing belt done. I also swear by BG 44k every other oil change. I buy it off Ebay for around $12-15 depending on how many I buy. Don't forget about changing trans fluid too. It is a simple drain and refill, check on here for procedure. I did that twice prior to 100k. There is a great write up on plug changes here too. Other that that change ALL of your filters. Just check/search the forums for info. Good Luck
Honda Odyssey Forum
Odyclub community is the #1 forum to discuss all things Honda Odyssey: minivans, safety, service maintenance, mods, and more.
