I could use some help solving this error code. I think it's the ECM relay. Can anyone tell me or show me a pic of the relay and location?
Thanks in advance,
Not sure where it is on this particular model but under the dash - driver side is a good place to check. Usualy not the easiest things to get at if I recall correctly.
2016 Touring Elite
Before you get too deep in this, check your battery terminals and the load sensor on the battery negative terminal. A quick google search shows that either of those things can cause that same OBD code on Hondas.
-Charlie
