Nice wheels. You'll probably need hubcentric rings to go with those wheels. Also, I would make sure the lug bolt size is 14mm.
IIRC, there's a member here running 20 x 8.5, 38mm offset wheels and I don't recall him having issues.
Hopefully other members will chime in.
Good luck.
I'm telling you those 19" wheels really look very nice on the Ody!
BTW, I was interested in 5Zigen proracer 520 zr wheels and although the bolt pattern was 5 x 120 - 37mm offset, I was told it would not fit because the bolt holes were only 12mm where as the Ody uses 14mm. 5Zigen rep said they can do custom work on the wheels, eg drill to 14mm as well as shave the back of wheel to make it 40mm offset - less agressive fitment. In the end the cost was too much - $275/wheel.
