1 - 12 of 12 Posts
Super Moderator
1999-2004 Honda Odyssey Body Repair Manual
http://techinfo.honda.com/rjanisis/pubs/BR/OD1999/OD1999MAINIDX.pdf
Here is what is required to be able to access the Honda/Acura links:
1. Open this Honda eStore link: http://estore.honda.com/accesssory-installation-instructions/display-installation-instructions.asp?make=honda&year=2004&model=Odyssey&modelname=Odyssey
2. Open any Honda/Acura link
Note: The Honda eStore link allows access to the Honda/Acura links for ~ 1 day, otherwise you will then get an error message. If you get an error message, just follow the steps again to regain access.
Thanks for sharing. I tried downloading the Body Repair Manual PDF, but I only see one page. When I try to click on the chapters, it doesn't take me anywhere. Any ideas? Thanks.
Super Moderator
You are not able to download this file. You can only view it as an interactive PDF.
If you save EVERY LINKED PAGE to the same folder. It will work like normal.
Did that with the ETM. Time consuming, but I think I got it all, except for photos so far.
cant get this to work
I have tried in all three browsers to get this to work. I can access the newer model odyssey manuals but cannot access this one.
Super Moderator
Discussion Starter #8
Still works fine for me using Internet Explorer 11 on Windows 7 64-bit.
What exactly is your issue?
Sounds like we have the same os and browser. I open the link to the estore in a tab or in a window, leave it open..... try to open the pdf and it immediately goes to LinkDeny
I really need info on removing the entire dash on my 04 so I can salvage the wiring harness.
Super Moderator
Discussion Starter #10
Try just opening the Honda eStore link and then close the browser. Then open any of the links.
NEW HONDA OEM SYSTEM UNIT, MULTI PLEX CONTROL (P/N 38800-S0X-A02) ODYSSEY 5DR
Anyone know if this fits a 2003 EX?
1 - 12 of 12 Posts
