1 - 20 of 61 Posts
Super Moderator
The eStore link opens in a new window. minimize it. NOW try the pdf link...Ah HA.
When I click on the PDF link I get:
You are not authorized to view the content on this page.
If you believe you have received this message in error, please contact the Support Center.
Please go back or return to the home page.
Follow the steps in the first post.
Step 1: Open eStore link. Don't close that window, just minimize it.
Step 2: Now click on that PDF link. It should now open.
If you want to perform the burdensome task of saving EVERY LINK on EVERY PAGE to the same folder,
you can have a fully functioning copy for yourself. I've copied all the main links, but not all the photos and connector diagrams.
AH! I had clicked on the eStore link and it opened in a new tab, then the PDF wouldn't work. Opening the eStore in a new window make the PDF work. Odd.
Hi. Only getting content page on the PDF with clickable buttons, but nothing happens. I've tried all combinations of opening new tabs with the estore. Is this PDF still active? Is there another way to access it? I'm having massive electrical problems. Thanks.
I was trying to open the links at the same time you were. Same result, nothing opens.
Super Moderator
Discussion Starter #10
What setup are you both running? I am using a Windows PC with IE9 and it works fine.
I was running Windows with Chrome. Worked fine when I switched to IE. Thanks!!!! The diagrams helped me narrow down my problem and find the solution. An almost inperceptable break in a 7.5amp fuse that was causing about 8 things not to function correctly. A mechanic friend and I had checked this exact fuse at least twice before. Thanks again!!!!!!!
Same here. The biggest problem now is the links don't work in the saved PDF. You still have to go to the live page to get the various pictures and schematics. This is a huge amount of info!! I'm going to put a link to this page in the folder with the PDF's I've saved.
I'm not very good on computers. have 2002 with radio and power outlet blowing fuse all the time. What could be my problem? Much thanks in advance!
You may have coins in the CD player - seriously.
Or the accessory socket has fallen out of its position and shorting.
1 - 20 of 61 Posts
