NEW TO THE SITE HERE AND FIGURED I WOULD POST MY ISSUES HERE TO SEE IF ANYONE COULD HELP ME OUT?? WELL, I'LL START OFF BY SAYING THIS VAN HAS BEEN GREAT TO US, BUT IAM NOW AT MY WITTS END!!. I JUST GOT DONE REPLACING THE CONTROL ARM BUSHINGS, STRUTS, SWAYBAR BUSHINGS AND LINKS, CALIPERS, ROTORS, AND PADS. AFTER FIXING ALL OF THAT, MY WIFE ASKED ME TO LOOK AND THE REAR WIPER, WHICH DID NOT WORK AND HAS NOT THE WHOLE TIME WE HAVE OWNED IT.... SO, I CHEKED THE FUSE AND THOUGHT IT WAS MISSING THE FUSE, BUT APON FURTHER INSPECTION, THE SPOT FOR THE FUSE DID NOT HAVE THE SMALL FEMALE COUPLERS ON THE BOARD TO ACCEPT THE FUSE. NEXT I PROCEEDED TO TAKE OUT THE FUSE BOX THE INSPECT A LITTLE FURTHER. I ENDED UP RIGGING SOME FITTINGS ON THE BOARD AND PUTTING IT BACK TOGETHER.... COME TO FIND OUT, THE OUTLET THAT I RIGGED UP WAS NOT EVEN FOR THE RR WIPER, IT WAS FOR DAY LIGHTS!! THE VAN WAS NOT EQUIPPED WITH THEM TO BEGIN WITH!!! I PULLED THE FUSE OUT OF THE DAY LIGHT SOCKET AND NOW THE VAN WILL NOT SHIFT OUT OF PARK, NO TAIL LIGHTS,(BUT BRAKE LIGHTS WORK), NO INSTUMENT LIGHTS, CLOCK LIGHT FUSE BURNT, ELECTRIC LOCKS ONLY WORK WHEN RUNNING, CANNOT ROLL DOWN PASSENGER SIDE WINDOW FROM DRIVERS SIDE, AND THE AIR CONTROL SHUTS OFF WHEN YOU SHUT OFF THE VAN INSTEAD OF BLOWING WHEN YOU RESTART THE VAN. NO, I DID NOT PULL THE BATTERY CABLES BEFORE PULLING ALL OF THE PLUGS OUT OF THE FUSE BOX!! I AM SURE IT WAS A DUMB MOVE, BUT ITS DONE NOW. "CHECKED ALL FUSES AND REPLACED THE BRAKE SELONOID.... STILLNO GOOD!! ANY HELP GUYS??
THANKS!
JOSH
:huh:
THANKS!
JOSH
